1 - 20 of 72 Posts
Could someone help me figure out how bad this turned out. Thought about buying this fifth wheel, took it camping, then went by the Cat Scale. Owner said it weighed 14500 loaded, so I weighed it. Weighed just my truck, then weighed truck and camper. Hopefully I can post the pictures.
Truck only
1091875
Truck and Camper loaded
1091876
Truck Data
1091877
Rectangle Font Parallel Number Screenshot
Font Material property Receipt Temperature Rectangle
Truck is a 2016 Chev 2500HD Duramax 4x4 Crew Cab Standard Bed SRW
You know the total weight of (truck plus camper) and truck (only) so subtract truck only from (truck plus camper).
Ok, so camper weights 14,620. What is my pin weight? Or do you need more info to calculate that? I’m just thinking that I am way over on my pin weight, putting too much weight on my rear truck tires? Thank you so much for your help.
Looks like your trailer weighs 14,660 and your pin wt. is 3080. The weight of your trailer hooked up to the rear of the truck shifted 40 lbs. from the front axle to the rear axle.
With those #'s it looks like you're over the GVWR and the Rear Axle Wt. Rating (RAWR). 3/4 ton truck?
Yes, 3/4 truck. How much am I over on GVWR and the rear axle?
All your images above showed up 3x by the way.
There another sticker in your truck door jamb with tire loading information, and your payload (cargo carrying capacity) at the time the truck left the factory. You have to subtract anything in the truck from that number, including your pin weight, to see where you’re at.
I like this weighing resource from RVforum.net… click the Download button to view: https://www.rvforum.net/resources/weighing-travel-and-fifth-wheel-trailers.83/
Although there are exceptions, most 3/4 ton trucks lack the payload to safely carry the pin weight of a lot of 5th wheels on the road.
Since you are looking at weight ratings, check the weight rating of your tires and compare this to the weight of your rear axle with the trailer attached. States police the weights differently, so it's always best to talk to a state trooper/highway patrol officer to see what they do in your state. And also ask about the registration weights. Lots of variations there also.
If you have aftermarket wheels you may want to check to see if they are rated for that kind of weight. Most are not.
2016 Chevrolet Silverado Duramax
With that kind of weight, you need a one ton to tow it safely. My cargo carrying capacity is 3,800 pounds. I wouldn't go over 2,800 pounds of pin weight.
I have OEM 20” wheels that currently have load rated E tires at 3195 lbs. And I’m learning that is the highest rated tire that will fit my wheels. And today hopefully I can find out what my rear axle is rated out. Looks to be a good difference in the gear ratio .
Everybody has already answered your question, and you have the answer staring you in the face. The sticker in the pic you posted clearly shows the rear axle gross weight at 6200 pounds. And as was already stated, you are 480 pounds over. Yes, you are over weight. Yes, that is too much trailer for your truck. And as far as gears, every duramax pickup until 2020 came with 3.73 gears.
And, a gear and/or tire change isn’t going to make up for the fact that the truck is overloaded. 👍🏻
The rear end in the 3/4 ton, 1 ton SRW and DRW trucks are the same. The only difference is how many leaf springs and the weight rating of the tires. If you modify accordingly It will increase the load carrying capability. Obviously the sticker on the inside of the door remains the same.
Last Camping trip with the 2500
Steer Axle: 5100
Drive Axel: 7600
Trailer Axel: 15300
Gross: 28,000
This was after camping for 1 week and all tanks empty so not included is:
Firewood
Water (Dry Camping) always bring water 130 gallons
Empty fuel station 60 gallons
Truck had 7500 lb Bags
2500 lb springs
Tires 3860 lb
I’ve heard it stated many times that the 3500HD axle tubes and other parts are thicker. I’ve never cut one up, I can’t verify, and even though the application shows the same axle in 2500HD and 3500HD applications, I’m just saying what I’ve read numerous times.
Have you read any of the replies to your original post??
Wouldn't it be nice if there was a thread with definitive information on vehicle weights and capacities in terms of both the laws of man and the laws of physics? And wouldn't it be even nicer if it was a sticky in this very section of the forum?
Oh, wait, here it is...
Yes I have. I have learned a lot. Except for the one grumpy reply. I’m not a truck professional, but to the ones that have been trying to help me, thank you a lot.
Discussion Starter · #20 ·
Now that, is a wealth of information. Thank you for posting the link.
1 - 20 of 72 Posts
