I am fairly familiar with workin on vehicles, I just never have tackled an injector problem. I need help, preferably a step by step process with removing driver side injectors on a 2003 LB7 injector swap, entire driver side.
X2. Hex bit with a small box end wrench to turn it.3/8 swival is what you need i actuall had to get a turques bit and a small wrench to break it, its tight and a pain in the a$$ i did it from fender well.Do yourself a favor and run out and get some stainless hex head bolts to replace the allen heads with for the next time you go in.
