When I swapped over from the allison to the zf6 I had clutch bleeding troubles the pedal would just get hard as a rock so I decided to try removing the check valve and boom 300 pumps later I had a clutch pedal but it wasn't quite right so after taking with a buddy that helped on the project we decided the check valve needed to be in to completely bleed the clutch system but when I tried reinstalling the cheak valve it did the same thing for the second time the pedal was just hard as a rock after pumping clutch for a while. I need this fixed asap Any help is appreciated
02ecsb lb7/zf6 284k
Stock intake pro fab intake horn
Stock exaust ppe boost valve
P0102 code that I can't get rid off
Efi live not on the truck yet
02ecsb lb7/zf6 284k
