1 - 15 of 15 Posts
Ok guys im getting pissed this hid kit I bought is not working, when I start my truck at night I have the automatic headlights and some times the drivers side hid wont turn on it just does a quick buzz, so then I have to manually turn them on like 10+ times till I can get it to turn on if it even will, I checked all the connections an their snug and tight, I literally only have like 20mins on this kit, and the guy I bought it from is being a douche and wont help me out at all.
Things I have done:
Changed the stock 15amp fuse to a 30amp
Removed the DRL Fuse
Brand new batteries for the truck
Here is the kit I purchased
Im now looking at this kit but have questions, what is this "box" connected to the ballast? Like a built in relay or what? An this guy will give me a lifetime warranty so im planning on buying this kit an hoping like hell it wont give me any problems.
Any help would be appreciated, only thing I have in the truck that draws power would be my edge monitor but that shouldnt draw tons of amperage would it?
My hidS are acting like that. When the truck sits for awhile my passenger side one won't come on until I manually turn them off then back on but I only have to do it once after that its all good and if the truck hasn't been sitting long all works normal. I'm going to try and run a stand alone relay and see what happens
did you uses dieletric grease on the connections? Why not get a DDM kit like most guys here? I thought that's what you had
I used the cheap chinese ones(most digital hids are anyways) from ebay on my 1500. $30 and a year later theyre still working.
Sounds like the ballast is junk. Any warranty?
No not a DDM kit. I used grease, an because this kit was only $40 an the guy came to me, he said their is a 2 yr warranty if he installs them but wanted $25 to install so I said no.
Mine are ddm
Yea that's what I was thinking figured I would try make a stand alone relay first and then if that dosnt work order a new set and just have a Spare.
Can the ballast go bad after like 20mins of use?
I bought a similar looking kit last year ($45/pr, chinese, no brand name) at an expo and nothing worked when I plugged them in. When I used some loose wires and jumped them off a separate battery they worked fine, so thought maybe the connectors are defective, but no clue yet. Still sitting in the garage. YGWYPF.
return this kit? You were sold a defective kit
I would try switching the ballasts and see if the problem stays on the same side or not... Then u will know if its the ballast or not.... That way if it is something wired you don't have to buy a second kit and have it do the same thing.
I know with mine you can plug the trucks bulb harness in two ways. At first the first one I connected didnt work. Just had to turn the harness around to reverse the polarity and they worked fine. Could be the case for you :thinkkkk
1 - 15 of 15 Posts
