Just about anything that causes the engine to work harder will raise the EGT some. Also anything that restricts air flow through the intercooler or raises engine temperature will have an effect. The most likely source of higher EGTs though is a restricted exhaust. Since you have removed much of what causes exhaust restriction it does not seem likely that it is the source of your high temps but it is still worth a good look to be sure nothing got bent or collapsed in the accident.
Removing the EGR will reduce the amount of heat going into the intake which will have some effect. Only time will tell if it is enough to satisfy you.
For what it is worth, modern catalytic converters rarely cause problems. They flow well and don't melt the way older ones used to. Since they do no harm and help the environment, my general advise is to leave them alone. Of course if you are going to larger exhaust pipes you would need to remove the cat or get it modified to match the pipe. For a stock engine, larger pipes are not much of an improvement on the flow.
The FASS 165 lift pump is way overkill for your basically stock engine. I've done the calculation here many times so I won't repeat it but 25 gph is all your engine can use in any case. Doubling that to 50 gph to cover age related deterioration of the pump and partial restriction of the filters would cover even the most extreme cases. If you check out the fuel filter thread that is currently running you will see that many filters are only rated for 50 gph. Unless you provide a return bleed for the massively excessive fuel flow, all of that extra capacity will mostly go to waste and may even cause mischief, though not likely. People who build 1000+ HP engines with twin turbos and two CPs with high capacity pumping units in them can take advantage of the high flow rates of the bigger lift pumps but for stock it is of no value.
There are over sized injectors to fit your engine. The advantage of larger injectors is that they inject the fuel faster so it has more time to burn before it is exhausted. That can lower EGTs because more of the energy is removed during the power stroke, leaving less to go out the exhaust. Fast injection is the equivalent of advancing the injection timing, which is a standard way to improve power and economy, at the cost of emissions and some additional stress on the engine. If you had leaky injectors, just putting in good ones may help with exhaust heat but the 30-45% over injectors might have done more.
I'm not trying to be critical or make you feel bad about anything. You just seemed to feel short changed by the amount of response you got so I thought I'd chime in. Everything I have mentioned is contained in multiple threads. You could have found it by simply researching the site. I know that takes a lot of looking but it can be done. Many members here don't feel obliged to help those who want it all laid out for them. I think it is worthwhile to get someone started but then I expect some personal responsibility for filling in the blanks.
There are people on this forum who will argue with everything I have said. Perhaps they are right and I'm wrong. You decide.
