1 - 2 of 2 Posts
So, today I decided to install the merchant automotive High idle kit in my 2002 Lb7. I installed it and it didn't work. I took everything apart and saw the the pin had slid back. I reset the pin supperglued it into place smeared dieletric grease over everything, and reinstalled everything. Still didn't work. This all occured with the edge juice with attitude tunner installed. On the tunner i noticed that my transmission temparateure was reading 0 degrees aswell. This was the first time i had the tunner installed in a while as i had it off and decided to install it when i did the high idle mod. I also tried to use the high idle after unplugging the edge nothing seemed to work.
Does anyone have any ideas on what is going on and what i could do to fix it.
Call Merchant. Usually they are pretty helpful when you run into problems with their stuff. If no joy there ask Edge if they have any ideas.
1 - 2 of 2 Posts
