1 - 1 of 1 Posts
Selling a set of homemade EGR delete plates. The up pipe plate ties into the EGR support bracket to keep the EGR riser baffle from vibrating and cracking. The plate for the intake tube ties into the bolt holes below it for support and holds the intake elbow in place. I ran this for a year on my stock turbo at 30-35 PSI with no problems.
Plates are made of 1/4" steel. EGR riser plate uses a factory steel gasket to seal, and the intake tube is sealed with RTV. Intake tube is drilled and tapped (1/8" NPT IIRC) for a boost gauge.
$50 shipped for everything pictured (except the brass boost gauge fitting), including the intake tube and EGR bracket.
Here is how the intake tube support brackets work.
1 - 1 of 1 Posts
