Hello, I have the AD 150 installed, but for the moment i have it hooked up to the trailer prk lights fuse, which is only hot if i turn my headlights on (didn't realize this at the time of installation) so i was wondering if anybody knows of a fuse that is hot with the key on? Thanks!
Discussion Starter · #2 ·
bump......
radio would be my first choice. or get a spade connector and stick it in a acc plug in the fuse box
XBoxLive: RenegadeDuramax
Use an empty place in the fuse box and run a dedicated circuit for it. Look at the wiring schematic diagram that came with the pump and use the appropriate fuse. When you tap into other circuits, it usually will only cause problems.
Banned
Ya there are a ton. If you grab a test light and hook it to a ground then probe the rear of the fuse youll find out what does and doesnt have power.
I use the air bag fuse for power for my amp.
Grab one of these fuse holders. They give you a fused power and a place to fuse the original.
