1 - 8 of 8 Posts
have any of you felt your tail pipe after a drive?
I came home last night from a 20 mile drive and just happened to feel my tail pipe...Holy Crap! That fucker HOT. Not burn your hand hot but pull your hand off hot.
Slave to the Interwebs
Yep. With EGTs staying around 800-1000* for 20 minutes it will get hot. Even at the end. Do you run any gauges?
Tennessee Smokin'
Hell yeh it gets hot. Check your egts just at idle. I know just cruising it reaches around 6-700. I know some of it is lost between sensor an tailpipe but it's still pretty hot.
ive never really tried to touch a tail pipe after running a vehicle at all common sense tells me its hot. That and i have burnt my legs on motorcycles by hittin the exhaust before
I would certainly do that if you are running a hot tune with the EFI. YOu can see Temps in the 1400-1600* range. Temps that high for a long time will eat a forged aluminum piston.
I run the economy tune 90% of the time. 4 is my DD 100hp tune and that barely gets used.
I think I was just playing with the low speed roll ons last night. 10mph or so and lay the pedal down is WIN. whoosh and the tires break loose.
Banned
You should see the temps on a regening LMM at the tailpipe. I saw over 780 degrees with a temp gun.
1 - 8 of 8 Posts
