1 - 9 of 9 Posts
Ive got a 04 single cab sittin on stock 16's with 285 procomp mud terrains and im lookin to go a little bigger because i cant hold traction with that PPE cranked up. What i really want to know is if i crank the torsion keys up how big can i go? Would a 315 be possible? or maybe even a 305? Any help would be great, Thanx Alot!
i have my TB cranked a lil w/ keys
and i run a 305 45 22 tire...
which is a 33x12.50
Ive seen 315's/35's with the torsions bars cranked and some trimmin
Yeah im putting them back on the stock wheels, I just really cant afford the lift right now so i just wanted to see what would fit. so is it just the front skirt that needs trimming?
I just cranked my bars 6 turns on a 2006 to clear 305 55 20. Only had to trim the front, plastic valence. I dont know if the trucks prior to 06 have enough clearance on the bolt to crank high enough without a different torsion key. You might need the leveling kit with a different key to get that extra clearance for a 315 tire, but just make sure you leave 3/4 inch between the uca and droop stop for ride purposes if you do start cranking the torsion keys. And dont forget about an alignment afterwards.
· I'M YOUR HUCKLEBERRY
x2^^^..........
1 - 9 of 9 Posts
