Hello Everyone,
I am a new member, just took delivery on my 2022 3500HD Denali last week.
I ordered the truck with dual alternators thinking that I would have increased current to charge batteries in the RV. However, I think that the RV charging pin is limited to 40 amps by a fuse in the truck. So I have the following questions for the group:
1. Is the charging current to the truck's RV electrical connector limited to 40 amps with the dual alternator configuration?
2. Can the 40 amp limit be increased to approximately 100 amps and if so how? I don't consider simply increasing the value of the fuse to 100 amps to be a safe option.
The reason I'm asking is because I'm installing a 24V battery array in the RV to power a whole house inverter solar system and I will need to supply 70-90 amps to the 12-to-24 volt battery charger that will be charging the 24V battery array in the trailer when the truck is connected. If the RV batteries go low and the charger draws in excess of 40 amps I could end up blowing the 40 amp fuse on the RV charging line.
Cheers,
Mark
Nope. The wire is 10 AWG and can only handle 30A. But if you do the math on the voltage drop for 30A through about 30 feet of 10 AWG, well...it ain't pretty. That connection is really only good for 15A or so, in practice.
If your trailer inverter is also a charger the way to send large amounts of power to the trailer is with an inverter on the truck side to provide 120 VAC (or even 120/240 VAC split phase) and connect that to the power inlet on the trailer. There's a link in my signature with some details of how I did this on my truck. When we are en route with our fifth wheel I have the 120 VAC input on the trailer energized from an auxiliary outlet in my truck bed, fed by my inverter. I had to relocate the power inlet on the trailer from the side to just under the front overhang though.
If you really need high current DC from the truck and can't use an inverter, you can look at the connectors used for snowplows, although I think if you want 100A over 30-40 feet within acceptable levels of voltage drop you'll probably need 2/0 AWG welding cable and most snow plow connections are 4 or 2 AWG. A quick look at Amazon reveals there are connectors compatible with 2/0 though, so it is possible. But I'm partial to the inverter solution for a variety of reasons.
Update: I don't know what kind of DC/DC charger you're using, but if it's anything like my Victron stuff, there's an "interesting" aspect of its behavior of which you ought to be aware. I have an 18A, 12/12 VDC Victron charger that takes input from the 12V AUX circuit on the trailer's 7-pin connector and is connected to my lithium battery array in the trailer. It's there just in case I have to tow the trailer with another truck and want to be able to trickle-charge the batteries if it's nighttime and the solar isn't an option, etc. What I found is that the internal logic in the charger is set to provide
constant output power of about 220 watts; this is
regardless of the input voltage. The problem is that if I sized the fuse for 18A assuming that the charger will see 12V on its input terminals, then if the voltage drop is such that the charger sees less than 12V it will have to
increase the current to achieve 220w and hence will blow the fuse instantly. This is exactly what happened when I originally tried to use their 30A 12/12 charger which is programmed to deliver a constant 360w. The implied current at 12V input is 30A, and at 30A the input voltage drops to about 11.8V (assuming 14V at the alternators). 360w/11.8V = 30.5A, and since the current just increased, the voltage drop will also increase, and it becomes a vicious cycle where all of a sudden it's trying to pull 50-60A and only seeing about 7 VDC on the input terminals and that's when the fuse blows (this happens in seconds). Even the 18A charger is a problem because 220w is just too much to push through that little 10AWG for the distance between the alternators and the charger (which includes at least 10 feet of wire from the receptacle to where I mounted the charger).
Anyway.
Just forget the auxiliary power circuit for anything over 15A; it's not going to happen. You're going to be doing some heavy duty wiring with ANL fuses and hydraulically-crimped lugs, etc. And make sure you
do the math on the voltage drop before you embark on any of this because the materials won't be cheap.
