So curiosity/possible concern for me. My LILY, stock motor, Edge programmer, 6" lift with 35s, I've noticed when in extreme mode, I'm running 4-6 lb of boost at 65-70mph. Does that seem high or is anyone else in the same boat? I just replaced the AF, and put some Howes in the tank to help the fuel system out. Also, what is normal balance rates for the injectors? Mine are all between -2 and 2. Thanks guts...always learning here
what are you measuring the boost with, analog or digital gauge? flat, hill, head wind??
Measuring with the Edge programmer. I wait til flat ground to measure. Its JUST enough boost tk hear the Turbo, not loud but barely. I figure that's prob about right but I wanna check with others
I think your ok. I've ran higher into a massive head wind 50 plus Mph. I've also noticed if I turn my efi to my economy 90 hp tune I'm pretty sure it's timing advance and boost drops
Thats the range mine usually runs at that speed, also going off of edge insight CTS analog gauge.
