1 - 13 of 13 Posts
I plan on doing the switch to amsoil and want to know how much of each fluid i need to get to do both diffs trans and t-case.
Thanks
Administrator
rear diff on mine took about a gallon, the front took 2 qts. The transfer case will take 2 qts too or if you put 5w30 in like some of us have, it took 3 qts filling it through the speed sensor hole.
Trans is about 7 qts for a drain and refill...I just bought the 2.5 gallon jug.
great thank you!
If he is switching to a different oil shouldnt he change ALL the tranny fluid??? like a flush???
IIRC it holds nearly 5 gallons
Dont own a bank, just a flush machine:D
And a flush isnt that expensive around here anyway, I run cheap fluid but still wouldnt mix a bunch of different shit together
they told me you cant flush a allsion, so i ended up doing the hoot method
Administrator
A flush isn't recommended on the allison. It is perfectly ok to have half normal & half synthetic. I have done a drain & refill twice. By this time it is almost all synthetic.
I dont understand why you cant flush them or why it isnt reccomended.. I do it quite often, works great!!!
I can see why someone may not want to do it using synthetic because its so damn expensive!!!
I was also told by several people (including suncoast) not to use synthetic with my kit.
Administrator
Maybe MikeL will elaborate why you would not want to flush it.
My dealer told me they couldn't flush my allison. The first time they just dropped the pan, changed the filters, and refilled. I have since drained and refilled it one more time.
It may depend on the machine that is used when the flush is accomplished too. I know I have read it is not recommended to flush the allison though.
I just unhook the cooler lines and flush!! Hope im not doing something I shouldnt!!
Vendor
To the OP, OB1 is correct. If you are need of AMSOIL fluids and would like to save 25-35% off retail, please contact me for more information.
A manual flush like scott indicated is fine and a lot of folks go that route. Allison does not recommend power flushing the tranny though.
Take care,
1 - 13 of 13 Posts
