I am new here and hoping that someone can clue me in.
I have 2006 LBZ that has just 109k on it and it decided to throw the P0088 code, which I have reearched and found out is likely the fuel pressure regulator. So, I have a couple of questions:
1) How much is the OEM part?
2) How much should I expect a dealer to charge me to install one?
3) After the code came up, the truck started running very badly but I had to drive it about 75 miles to get it home....how much more damage did I potentially do to the engine? I have been told that if driven like this you could blow the motor/burn a piston.
Thanks in advance for your help and advice.
replacing mine with the race valve took less then 2 hours. its really easy to do yourself.
