1 - 20 of 521 Posts
Let me first say there are real nice quality other kits on the market but I think this one is unique and so far I really like it.
Out of the box the kit looks like this.
As usual you have to start somewhere and I started by removing the grille. On the GMC there is one bolt and six snaps that hold it on. But first remove the cover taking off the 6-8 plastic snap pin retainers off and the bolt for the grill.
Next pop the two snaps on the outer ends of the grille both sides and then the four main snaps then lift out. Kinda looks like this after you get the grille off.
I then removed the air filter box, the plate under it, the bracket under that, and the CAC (Charged Air Cooler/Intercooler) hose on the discharge side of the CAC so you will have access to the hoses and fitting going into the radiator trans cooler.
Next I removed the cooler lines from the transmission. Remove the black caps and then use a blade screwdriver to remove the clips holding the aluminum hoses into the fitting and then pull the hose out.
I had a problem removing the upper line return from the cooler as I have the DE Down pipe and DE QT Turbo back 4” exhaust and the upper line needed another 3/8” or so of clearance to remove. So it seemed the easiest thing to try was to remove the fitting in the transmission. A 32 mm wrench worked fine but maybe a slightly smaller one or US size might have been better. A friend told me that is was a 1 1/4" size. Anyway, I backed the fitting out and was able to move the line around and get the fitting and line loose. Side bar, have a drain catch available of fluid residue in the line and lines to be broken. I also removed the supply connection quick fitting at the same time.
More Later
Reactions: Clark in Va
Discussion Starter · #2 ·
Next I removed the lines from the transmission cooler and the threaded fittings also. Be careful when loosening the fittings as the aluminum cooler is very soft and a counter torque is necessary to prevent twisting the ends of the cooler. Also there could be additional fluid drainage from the fittings at the cooler and the other ends at the transmission. Did I mention that I don’t like loose transmission fluid. It can get real messy. The fitting that you use in the trans cooler are the 90* short fittings.
Now I replaced one line at a time and the first one I did was the outlet of the trans cooler back to the transmission (upper one). The fittings in the transmission, radiator cooler, and transmission cooler I left loose and after hooking up the hoses I did the final alignment and then tightened the fitting both the hose and the threaded body fittings. When removing the old lines I cut the flex hose and they came out so much easier with no hassle. After I replaced the return hose I removed the old and then replaced the outlet of the radiator to the transmission cooler line (straight fitting on one end and a 90* fitting on the other). I left all hose and cooler/trans fittings loose until the final alignment (after all hoses installed). And last I removed an replaced the outlet of the transmission to the Radiator Trans cooler line. I ended up removing the outlet of the radiator to trans cooler line at the radiator so I could get the lower radiator cooler line installed and after I got it final installed (all fittings tight) I reinstalled the CAC to ENG hose and then did the upper radiator fitting alignment and tightened.
I then went to the inlet of the trans cooler and did the final tightening of these fittings (2). Remember to use a wrench to counter torque your tightening so you don’t bend and/or distort the trans cooler.
More Later,
awesome write up so far man. looks great
Discussion Starter · #4 · (Edited)
When installing the threaded fittings into the transmission (there are four 90* fittings in the kit of which one is about ½” longer) install the longer fitting on the bottom of the transmission as the shorter one will not work due to interference.
When installing the fittings in the radiator use the two with the large washers. The straight one goes in the upper bung and the 45* fitting in the lower bung. You will notice in the kit there was two extra o rings. Install these on the fittings that go into the radiator. That means there will now be two o rings on each fitting. This needs to be done as if you use just the o ring that is on the fitting the large washer will prevent the fitting from seating the o ring in its proper area and the fittings will leak. (Alligator told me that it wasn't necessary and they haven't had any reports of leakage with over 30 installations so far)
Last I went back and made sure there wasn’t anything sharp rubbing on the hoses at any place. I started it up and let it run a few minutes and checked for leaks before reinstalling everything so I didn’t need to do double work. There is a bracket that hold the hard lines next to the engine block that is a bit of a pain to remove. It has a 10 mm nut/bolt on it that has to be removed to get the old lines out. Also the lines from the transmission are routed different than the factory hard lines but I didn’t have a problem with that.
I will start a thread for discussion if anyone has any questions. Link to Thread
Thanks for taking the time to complete this!!!
subscribed
Excellent info!
"THEEPASUCKS"
Going to change my lines soon, this will help alot.
Good Job...:drink
What prompts you to notice they need to be replaced? I seen 07.5 lmm I thought that was pretty new to be replacing lines. Jw
Its an 07 Classic and I had it on the lift and was just doing a routine check of everything and wam!! there is was. If your truck is 6 months old and you have gone through a winter there is a good chance you have leaky trans lines.
Great write up and pictures, thanks for sharing. Does new body style grill come off the same as classic to do this job?
Wow, good question but hopefully someone will answer up.
Discussion Starter · #14 ·
I checked out the lines for leaks today and took a couple of more pics. No leaks and I was looking for any rubbing of the hoses and ended up installing to tie wraps/zip ties to help the lines alignment.
The first one was at the trans and if you look you will see where I rerouted the hoses which is better than trying to get them where the old hard lines were routed.
The second tie wrap keeps the hose from rubbing where they go up into the area front of the grille.
It is great knowing these lines aren't going to leak any more.
It looks like these lines are a 1/2 inch line. The ones from Husker are 5/8 inch.
Do the 1/2 lines provide enough flow and pressure for the transmission? Just curious.
They are 1/2 and also curious with above question.
The lines are 1/2"/12.5mm see pic. They are plenty sufficeint to supply flow to the cooler.
Discussion Starter · #20 · (Edited)
Wait, do those COMPLETELY replace the hard lines?
Yes, and they also replace the factory fittings in the Transmission, Radiator, and Trans Cooler
1 - 20 of 521 Posts
