I just spent a few hours going over the Ign override systems similar to what Police cars use. And while there are systems out there that will do it, they cost $140 plus wiring harnesses. So I figured out a simple way to do it for a lot less money.
This is for installing a momentary switch in a Duramax that once pushed will allow the keys to be removed and the truck to still run. It is deactivated once the brake pedal is pushed, shutting the truck off.
I would also recommend adding the high idle feature to this, so that whenever the switch is pushed it goes into high idle. It is really important not to run diesels at low idle for long periods of time.
This could easily be adapted to other vehicles but the wire colors, numbers, and pins are for an LBZ because that is what I have the wiring diagrams for.
It requires;
6 relays (Good cheap ones I have used before are VPA 80238, they are $9 for a pair)
4 Circuit Breakers 30 Amp ($3 screw terminal style work great)
1 Circuit Breaker 10 Amp
16 or 18 ga wire
12 ga wire
eye terminals for 12 and 16 ga wire
Follow the diagram attached.
Basically run 4 12 ga wires from the battery, alternator output, or batt stud at the fuse block to the 4 circuit breakers.
From the circuit breakers to the relays.
From the relays tap into the 4 main circuits that the ignition switch runs.
Add a couple relays and momentary switch with 16 ga wire to control it.
Add a circuit going to the ECM for high idle and you're done. You will have to get 2 ecm terminal pins from a dealer for the high idle.
I will get more detailed instructions soon if there is any interest.
All in all I am guessing around $50 in parts and 2-3 hours in time. I will be doing this after my baby comes and everything settles down and can tell how long it took.
It requires;
16 or 18 ga wire
12 ga wire
