1 - 20 of 504 Posts
LHN...We ARE the Joneses
Today, I serviced the PS/HB system with a flush; I took some pictures and thought I’d share my procedure I do regularly to prolong the life of the PS and HB units and keep them functioning properly.
ITEMS NEEDED:
Drain pan
Large channel-lock pliers
5-6’ of 5/16” Fuel Line Hose (3/8" will work also, it's just what I had on hand. Clear hose to view fluid is another choice.)
Scrap piece of 1x6
Small funnel
2-3 quarts p/s fluid, Just buy a Gallon Jug, it's cheaper.
I'm currently using Royal Purple synthetic, but plain PS fluid is fine. I pull heavy in bad traffic and experience higher heat levels than the average user. I've experimented with few different syn ATF with mixed results. None proved superior, some were actually detrimental to performance. Looking for a synthetic PS fluid has proven to be an elusive endeavor. At this time of edit, only RP and AmsOil offer syn ps fluid. Again, regular PS fluid is fine to use.
Here we have the culprit at hand,
CAUTION: in the picture below, you’ll see the curved metal brace coming from the cowl. I STRONGLY recommend you place a rag, towel, blanket, or some kind of cushion in this area.
(Edited with input from DF member fflmlf)
Open the PS reservoir cap to relieve any excess pressure BEFORE pulling the return line hose shown below.
When giving the final pull on the LP return hose, the release/recoil will have the underside of your wrist striking this, with potential gashes and blood spilled on your truck, resulting in you cussing me later. GrrRRrr I pull mine regularly and it comes off much easier than one that's been on for 70-80k miles.
Compressing the spring clamp,
turn the hose left and right to break the seal, then pull back off the nipple.
There will be a slight leak of fluid from the hose end when removed, so have a rag or paper towel in hand to catch and not make a mess.
The curved end of the hose (with rag/towel over end) will hook over where the Hydro-Boost unit meets the Master Cylinder, it'll be out of your way and not leak more fluid out.
Re-using the OEM spring clamp, I secure the drain hose at the HB unit
and lay the board down to hold the hose in place with the drain pan in site from the Driver’s seat.
With the engine running and in Park, SLOWLY depress the brake pedal till it feels firm at the bottom and hold, turn the steering wheel from 12-3 o’clock and hold, release the pedal SLOWLY to the top, then bring the wheel back to 12 o’clock. Look down and you'll see the flow and then you can adjust your speed of press and release actions so as not to spray fluid out of the drain pan. It may take 2-3 times before you see the fluid start to flow.
Here we see the old, burnt, and dirty fluid beginning to flow.
.....................Continued on the next post, I'm too picture happy to conform here.
Discussion Starter #3 (Edited)
Part 2
Continue the same procedure alternately turning from 9 to 12 to 3 o’clock until you start to feel/hear the steering bind a bit, usually 4-6 pedal cycles, then turn off the engine.
Grab your funnel and refill to the bottom of the neck of the PS reservoir.
Hold up the funnel so you can see the fluid level coming up and not pour fluid all over, usually about a third of a quart at a time.
Climb back in, start ‘er up, and get after it again, repeating over and over till you see the fluid start to run clear. I know it is tempting to do but, PLEASE!, don’t leave it running while you refill the PS reservoir, the danger is too great to have your Left Arm get caught and have it get D-MAXED.
Here, we see the fluid is now running clean.
Leave the drain hose connected, check the fluid level in the pump, and fill accordingly to the Cold Line. It you over fill it, just pump the pedal a few times to drain.
Remove the drain hose, wipe the nipple clean of residual fluid, and replace the Return Line using the Spring Clip.
Start ‘er up, roll forward turning the wheel and feel the new ‘Creamy Cool Whip’ resistance in your steering, and yer ‘Good to Go’.
Consider also:
Your HB unit works in conjunction with your Brake system. Brake fluid is like a magnet for water/moisture and should be flushed annually to aid in longevity to your brake system components AND to keep the fluid's boiling point up to spec.
How To: Brake Fluid Flush
Also:
For as little as $35-ish, you can easily add a Power Steering Fluid Cooler to your HD.
How To: Add Power Steering Fluid Cooler
It's amazing to see the junk that comes out of the bottom of the system. You'll wonder how it ever performed in that condition. :D
VAGITARIAN :)
That's good post..pics help too
I guess mine need it,I tow some heavy loads once a week or so.Thanks for the DIY.I will flush mine now that I know how smooth it goes...THANKS:drink:drink
Discussion Starter #7
Much easier to perform than coming up with $400+ for a NEW HB unit! :D
VAGITARIAN :)
Smoke. It's what's cookin
NIce write up. Might have to give it a try. How many miles were on that dirty fluid??
Discussion Starter #10 (Edited)
Not sure on the miles, I don't even keep track on it anymore as my use is out of GM parameters anyway.
IIRC, under heavy use, GM suggests intervals of 20k miles. That’s a BIG guess as everyone’s definition of ‘Heavy Use’ varies as much as the Owners use varies under even more diverse conditions.
On one end is a light commuter that occasionally pulls the Bass boat out on the weekends. In between is the Owner that pulls 10k lbs, 2-3 times a week. I’m on the other end, sometimes moving 60+k lbs daily.
Add in level or hilly terrain, highway or city use, in light or heavy traffic with extended repeated heavy braking for more than an Hour, how can one pick a definitive point to schedule service?
I just look for the telltale signs of Fluid Wear for my intervals. When backing a trailer and applying the brakes while turning the wheel, you can feel and/or hear, the PS pump whine/strain and sometimes an unusual feel to the pedal also.
Many folks will drive their gassers for hundreds of thousands of miles and never think of changing their PS fluid, then seem perplexed when the unit finally gives up. :rof I have never seen or witnessed a PS pump failure in high mileage vehicles that had the fluid changed regularly.
It’s not uncommon for the HB unit to fail at 50-70k miles on many HDs that have lacked service in this area.
Discussion Starter #11
Update
Well, after flushing the system this weekend I also installed a set of 'Sulastic Rubber Springs'
https://www.sulastic.com
on My '05 3500, and I replaced the coupler on my GN trailer
Cushioned Gooseneck Coupler
I have to say, the combination of creamy steering and a feathered cushion ride has my dually riding and driving like an Escalade! :pimp
Did you buy direct from sulastic? How much trouble are they to install? Do you support the frame and let the axle fall when you install them?
Discussion Starter #13
Ignore the enclosed directions. Support the chassis with the rear tires off the ground, remove the Receiver Hitch and lift the axle at the differential to remove spring load. Remove the lower shackle bolts and then LIFT the axle to remove the top bolt ABOVE the frame.
There is No need to remove shocks or air springs to complete the install.
Available here:
..:: Nor Cal Truck ::.. ..:: Online Store ::..
This guy has ‘em on all four corners, impressive. The course should have him slinging around inside, yet the body stays relatively calm.
http://www.youtube.com/watch?v=NuTjZmd86js&eurl=http://www.duramaxforum.com/forum/general-discussion/8347-sulatiacs-springs.html
Discussion Starter #15
The cc-2 is (only) rated for 30k lbs.
Discussion Starter #17
Great. I've been running one since last December. A problem developed with the Rubber sleeve on the old one and they dropped shipped me a new replacement that arrived two days later, free, with return shipping included.
Standup guys that back their product. :D
Just did this power steering job today and all I can say is WOW. Thanks for the write up Hook. It was very easy following your instructions. Smooth as butter now. Mine was bad too, and low when I started so I used almost 4 quarts and still was a litle brown. Thanks again.
Brian
Brian
So this made a big difference for you? Hmmm i will have to try this out. . . How long did it take you?
I just did it today after reading this, first time it had been done with 100,000 miles now. Only took me about a half hour if that other than going out and getting the fuel line and fluid. The fluid was very dark and smelled burnt, the steering definately feels alot better. The write up by Hook'em Horns was well done, thanks for the info
1 - 20 of 504 Posts
