1 - 7 of 7 Posts
My truck won't start. Just cleaned the tank and put new filter on. Truck ran for a while but now won't even start. I even replaced fuel lines going to and from filter housing. Not sure what is going on. Getting really frustrated because I can't forsure diagnose the problem but if anyone has any it would be appreciated
Have you checked lines coming in and out of ficm to see if you're getting fuel there? Bled the system really good? I had to bleed the system several times when I disconnected lines when cleaning injectors to get it running.
Also make sure oring came off with old filter. If they're double stacked will suck air in.
Yeah I made sure filter was good? How exactly do I check fuel going in and out of ficm??
Ok so I get it started after a lot of cranking. Runs ok but not good. After I stop driving it is kind of smoking on the side of fuel filter but I can't seem to find the source! If I try to start it again it asks like it is losing its prime totally and won start. It must be sucking air but can't find where at all
I have a lift pump also so it shouldn't lose its fuel prime unless it's sucking air
1 - 7 of 7 Posts
