Howes Diesel Deffender
5.7K views 33 replies 11 participants last post by  bfmm
Has anyone used this in their Duramax? I just purchased my first diesel and want it to last a long time. 2024 3500HD HC 6.6L Duramax
#4 ·
Like @Piper One said no additive needed. Pick fuel stops with alot of activity. If it pumps real real slow, stop and find another station.
If you look at the fuel stations you use you'll most likely see advertising on there diesel pump or close to it where "there" additive is included. No reason to double down.
I run additive in every tank. Would definitely recommend as it DOES make a difference. I use OptiLube but there are other good ones out there. The stuff you find at the auto parts stores are junk unless maybe the Power Service stuff.
Reactions: Madbuzz41
#7 · (Edited)
I use Howes DD every once in a while in the summer, in the winter I use the diesel treat pretty much every fill up (mostly just for any potential water issues). My uncle was a long haul transport truck driver for probably close to 30 years and went to a lot of cold places in Northern Canada in the winter. He said thats all they used and never had any issues with fuel or gelling, etc and recommended it..??
I’m not so concerned about it in the summer (no freezing water potential) and in Ontario they use 3-4% bio-diesel (best lubricant and cleaner there is apparently) but I’m not sure it’s actually used in the winter due to its high gelling temp..?
For a long time I used and had good results (including keeping a cp4 alive) with Alliant power additive products. A local injector/pump rebuilder sold them at wholesale prices.
I figure it worked out to an extra 5$ per fuel up in the summer and maybe 10$ in the winter (the summer stuff was more concentrated lacking the antigel). The truck did seems to run a bit better. This was on a 6.7l cummins.
Sam
#11 ·
Ya, it's just not widely available at retail, like 'oh shit cold snap is coming better get some' kinda thing. Most of the on the shelf dealers were mostly marine last time I checked. I get mine from DPC in Edmonton (nice folks!) but order enough for the year. They make great stuff at reasonable pricing, I wish it got more shelf exposure is all.
#14 ·
My opinion, In a nutshell no.
Diesel supplement doesn't call for the truck to be plugged in till 0 degree F. Can you plug it in before that, sure.
If you are buying diesel in your area it should be treated for your region already. As @Piper One stated earlier if you happen to be traveling to a warmer region and buy fuel and bring that back to your colder region you may want to treat it to prevent fuel from gelling. If you only have your factory fuel tank I doubt it will matter, you'll be re-fueling in your region.
If your in an area that gets very/extremely cold it would be better on the engine to run 5w-40 for those colder months.. Below is from the Diesel supplement manual.
On a safety note, if you do ever find yourself in a position where the truck won't start/run on an extremely cold morning and you think the fuel is gelled, once it thaws out change the fuel filter ASAP. It is possible to rupture the filter during these types of event.
#20 ·
For reference, this is from 6 or 8 years ago. Temps are -12F (-25C). First pic is untreated fuel from an Esso here in Waterloo region Ontario. Second pic is Howes treated US fuel.
You can see the wax crystals on the side of the jar in the Howes (the fuel was given a swirl in the jars before the pics were taken). It doesn't look like much but with a 2 micron fuel filter in a Duramax it adds up quick before the engine returns enough hot fuel to the tank.
My apologies for these pics being so big.
