It is getting close for me to change my tranny fluid, the local lube shops wont even touch the tranny? why?
Its so easy a caveman can do it^^^^^ I think someone did a diy on the dp on how to get the old fluid out of the trans cooler also for the complete change of fluid...It is easy, and will take around 8 quarts of Dexron 6, you will need to buy a new spin on, and a internal, internal is easy, drain the fluid via the plug. next drop your pan. the internal filter is right there and pulls off. make sure you get the rubber O-ring off with it. push the new filter in. torque the pan bolts back on. (it's alum, so you don't want to over tighten) put a new spin on, on. and fill her up.
