1 - 12 of 12 Posts
2007 GMC Sierra LBZ
I doubt it will work without some major trimming to the fender.
What’s a good 3.5” leveling kit with arms
Honestly, just my opinion, but there aren't any. If you just want a level, the smaller, the better your ride will be. The more angle you put on your front end, the worse it will ride/wear. I didn't really want to, but wanted to keep a nice smooth comfortable ride and fit larger tires, so I ended up putting a full lift on mine.
Here's a website where you can see lots of different tire/wheel/lift combinations. Check out the gallery Custom Offsets | Simplifying the aftermarket truck world through teaching, tools and the gallery
Reactions: Sulfur
2021 Denali HD Fabtech Lift and 37s
I have 37s on a 6" lift and it all comes down to offset and wheel width. My 20x9s with 37s on a -1 offset barely rub at full lock. My 24x12s with 37s and -40 offset rub a lot, and caused me to have to remove the mudflaps and lower valance. Even with doing those 2 things I still rub. Give us the details on the wheels you plan to run (It appears you have factory wheels currently) If you plan to run the factory wheels with 37s a leveling kit will probably get you there.
2021 Denali HD
He doesn’t have the new body style truck, doubtful a leveling kit will get him there.
I plan on keeping the stock 20s on it, I haul my equipment around with a gooseneck don’t plan on putting another set of wheels on it it’s my first duramax work truck
Congrats on the truck! What year is it?
I've read of people putting 35's on stock wheels, and no lift. But I don't have any experience with that.
I have a ‘19 with the lift / level kit from rough county (yeah I know) , but it works fine and ride great. I fit 35” and only get a little rub on full turn. The tires rub on the frame a tiny bit.
And I have plenty of room in the front. With stock wheels, you need to make sure your not rubbing the upper A-arm.
And I think 35” looks good. It’s not over the top looking.
Should have come stock with 35's.
1 - 12 of 12 Posts
