1 - 7 of 7 Posts
Just got my truck back two days ago from $1400 and a month out of commision. Replaced a broken flywheel, cracked torque converter, and put in new seal/bushing and pump gaskets. I just icepicked my #2 and #7 injector connectors and I'm still have the same random stalling issue and trouble getting it to stay running when it's cold. I checked the ficm bracket and the wires are fine. To top it all off I now have a "service brake system" along with a "range shift inhibited" message. My only forward gear is 4th and it clunks going into gear. The truck is just running like total crap and I don't know what to do.... ideas??
nsbu switch
Discussion Starter · #5 · (Edited)
I found the problem. Looks like my front driveshaft snagged a wire. Could someone tell me where this wire is supposed to go? It branches off on top of the transfercase and it goes forward towards The large connector on the trans (nsbu switch?) I want to say it taps into the large wire loom in the upper part of the pic
I think this is where the wire came from:
Now I have to pray that I can figure out how to splice the proper wires back in
1 - 7 of 7 Posts
