1 - 2 of 2 Posts
Especially when somebody else failed to do it prior to me. Here is the list of parts changed so far:
Driverside wheel hub.
Transmission cooler lines.
Power seat control box.
WIF sensor.
MAP sensor.
Brake booster line from steering box.
Need a new wheel since one is bent.
WIF sensor was the latest part, the leads pulled out of the sensor during disconnect for filter change. They were corroded and basically fell off when touched. I've only owned the truck since December and have put 8k mileage on it. Anybody in the Mississippi gulf coast region have a spare wheel for me? Or a set of cheep aftermarket wheels that look decent?
Tyler:violin1
the way i look at it... if i do the work fixing i know it is done correctly & i know when it was done... when i buy (typically used) i go through on the fluids & check the trouble spots within the first month of ownership
1 - 2 of 2 Posts
