1 - 9 of 9 Posts
so i finally put a 5" flo-pro exhaust on my truck and love it but i noticed at times while driving i get a puff of white smoke...did it once when i hammered on it last night and while high idle today it would do it...mainly once i take off from a stop light or sign...newer to the diesel help please
the ice pick trick is for when your #2 or #7 inj harness goes bad. if that happens, you will know it. If it runs, it will only be on 4 cyl. The 'ice pick fix' is when you jam a punch or pick into the plug to make it gain contact again.
Not sure what your white smoke could be. Losing any coolant?
no coolant loss but i did pull the dipstick and smell a hint of diesel in there....its not so much once the truck gets up to temp. no smoke at idle either
Mine smokes blue when cold. Below 25* cold. Once it warms up and rings seat, it's fine. When diesels are cold it's normal to have some colored exhaust fumes.
Just a dumb thought, If your new exhaust has a oilly film or some type of protective coating on it from the manfacturer it might smoke a little or smell funny until the it burns off.
Discussion Starter #6
thats what i thought at first but then i noticed it kind of lags and sounds like it misses when it smokes like that i do have an edge juice with attitude in it could this be the problem? has anyone heard of this problem with the edge? Thanks guys i really appreciate all the help truck has edge juice with attitude 5" exhaust and 155k on it...i love the truck just wanna get it right again
get rid of the edge and get real tuning.. and if you smell diesel in the oil you might have a injector starting to go...
I would say its goin to need an injector(s). Check your balace rates. And perform a return test
Discussion Starter #9
i know i want to get efi real bad dont really know where to start can any of you guys help me out? maybe pm me with some prices thanks guys!
1 - 9 of 9 Posts
