1 - 7 of 7 Posts
I installed a ppe lift pump and wired it to a switch through a relay. When i flip the switch on the injectors get louder and it wants to idle rough. The fuel presure gauge reads 1-2psi without pump and 12.5psi with pump on? I bled the system of any air and have driven 10 miles and the condition continues?
ALso when I did the pump I installed ported rail fitings and a race valve to restrict the return? Can I not use the race valve with the lift pump?
Thanks for any help,
Thanks for the info I will adjust it tonight and see what happens?
The regulator never had an issue before? I guess the new PSI is a bit too much for it.
Hi, I'm Earth. Have we met?
Yeah to much psi will flip the FICM out. My truck will only take 8 psi and my wifes will take 14, so every truck is a bit different, dont go to high though or you can cause serious damage to the FICM!
I bumped down to 10 and it seemed to behave Ok. I have not had a chance to run it and verify that the issue is gone. I guess this weekend at the track i will just turn it down until injectors are smooth and not eradic?
1 - 7 of 7 Posts
