1 - 15 of 15 Posts
Recovering Diesel Addict
holy christ, that's nasty
Banned
Unfortunately replacing the fuel filter religiously will not affect what you are seeing.
Most of that crap came from when you unscrewed the fuel lines.
See this write up by Merchant Auto: LB7 Fuel Line Corrosion
That looks normal for any LB7.
Wow, thanks.
Banned
Sure,
I was also very surprised the first time I saw that!
Makes me wanna tear it apart just to see if mine look like that... they are probably horrible because I was the engine bay all the time.
I replaced my fuel filter the other day and noticed something in the lower section where the WIF goes. It looked similar to this but was more flakey like. I thought it might have been the inside of the filter rusting away. It wouldnt be able to move past the filter element to the lower section if it was coming from somewhere else. Would it ?
If you found it at the WIF sensor it's probably crap from your tank.
wow wtf so i'm assuming it's smart to replace the fuel lines when i do my injectors next?
Is it something to be concerned with ? At the time of the filter change I dumped a can of sea foam and diesel kleen
Not unless it is a lot, in which case it will probably plug off the suction in your tank, and you have to clean it... been there done that lol.
Just make sure you're regular with the filter change, no biggie, that's why it's there.
X2
that is why of one is bad you at least do all 4 on that side:drink
If they are fine leave them alone! All that crap comes when you unscrew them. Do not mess with something that is not broken:D
I know, I'm just messing around, I wanna tear something apart cuz it's break up here and I'm bored. Wife hasn't broke her ford for a while so I'm spending way to much time on the computer lol
Great write up, thanks for sharing !!:rockin
Public Enemy #1
OMG!!!! Mine were no where near that bad. I had one that was maybe 1/4 that bad if that. Mine went 180k
1 - 15 of 15 Posts
