I am a new member as of today. I have been reading the forums for 2 days now before I decided to join (Good group of people here) Anyways, I have a 02. INJECTOR pump was just replaced 3000mils ago, but the just recently having trouble starting ...so I decided to (replaced filter, checked lift pump no problems) shorty after all that; now truck will not start at all on its own. if a spray a shot of brake clean in the air box the thing starts right up. and runs fine; you can immediately shut off the truck after starting (engine at operating temp) and try to start; motor will not start with out giving it something more than WD40. I have driven the truck for another 3000 miles like this. The truck stays running and is on the go most of the day (3 starts max per day). about the only thing I am getting now is black smoke, performance is still there but "some" smoke at hard acceleration's. (more than normal)
Note: this 2500 is all stock. injectors where replaced 2 yrs ago; fuel in oil. and the pump is new. lift pump still good. filter new.
I I am not getting any fuel in the oil but I was thinking the injectors might be bad again (or a couple of them). the truck has to crank longer than normal to start... I am almost under the impression that the pump is bad or faulty...
