1 - 12 of 12 Posts
So I am going to be taking my truck to Fleece to get the headgaskets redone and getting EFI tuning also, and I was wondering whether I should put injectors in it or a FPE turbo on it instead.. I would like to get the turbo more but I didn't know which would be the best performance choice out of the two.
I would build the tranny first and go from there!
yup. build the trans first...if you still have a stock tranny then there is alot of power left in the stock turbo as far as tuning goes. but if you have to have one right now. do the turbo before the injectors
It's got a 6 speed in it, I figured that after I got the money to replace the clutch down the road then I would do that also.
so its a manual? id get a south bend before anything
efi
clutch
liftpump
turbo
injectors
etc...
Discussion Starter #6
yes, I already have a FASS fuel pump. For whatever reason the owner before me put one on there and that is the only thing done to it cept for exhaust.
get a clutch then some max effort efi tunes....once that gets old, then throw a turbo on
Its just a worktruck
Turbo
I think I'm going with 350% over injectors and quad modded cp3's should hold 600,000psi in the fuel rails...This batmowheel puts out adequate air for that...
But seriously do a turbo before injectors. Southbend dd before that.
I would build the transmission before either of those.
Even stock injectors/turbo w/EFI will toast your transmission.
He has a ZF-6. :)
1 - 12 of 12 Posts
