If i have to put injectors in my truck what is the best i need to go with?
I thought you could only get REMANS ... who's manufacturing NEW?i can get you brand new ones, no remans, for 225/injector they are not remans, plus 150 core for each, if it is a quick turn around i can probably keep you from getting the core charged to you
If you have fuel in your oil I would say it is obvious that your injectors are leaking...??I also have an injectore question. Can you use a PPE Xcelerator standard to tell if you have a leaking injector that is leaking into the oil? Got 10K miles on Pensecola diesel injectors and have fuel leaking into the oil.
