1 - 20 of 22 Posts
I installed my leveling kit tonight, it had the keys, shock ext. and 2" rear blocks. my question is, do I need a wheel alignment? I drove it home from my buddies garage and everything felt the same, just more rough ride. But i like the rough ride. do i need the wheel alignment because of the camber and what ever its called from over cranking the bars?
sorry i havent replied comp was dead, i dont know when it last had one. But maybe i should get it done tomorrow.
Ask one to be one
Its a good idea to get one done everytime you do front end work.
mine needed it. I waited and go the outside edges worn down some. I just put on a 3" spindle lift and had to do it also.
This is with leveling keys. 275/65/20 34"
This is the same tire and wheel with the 3" spindle added and then the keys let all the way out.
Notice that the bump stop is still in the stock location. Rides smooth this way. Dont forget my truck is 2wd.
did you use the torsion bar release tool on this or did you do it some other way cuz i have a kit waitng to put on but i need to find someone with this tool first haha cuz i'm not spending 150 on it
I borrowed a tool. Some auto parts store lend tools. It makes the job real easy. Just make sure you jack the truck all the way off the ground to make it easier.
i never though of using a gear puller thats a good idea i'll see if my buddy got one of them laying around his garage unless he can get his hands on the actual tool. and yeah i got mine up on a lift above the head so no worries there haha :drink
Discussion Starter · #15 ·
I went and got my wheel alignment done, and the front passenger wheel was 2 degree's out. He fixed that and now the truck pulls hard to the right? lol before without the alignment it would drive straight down the road. He said it was the camber he fixed.
find someone else to do ur aligment , caster has half the degree of pull as camber, + .50 degrees more on the drivers side for pull ON CAMBER to the left to ofset rd crown.try to keep the caster even and more on the positive side for better steering responce. the problem now days is a shop mentallity is " SET THE TOE COLLECT THE DOE"
Discussion Starter · #17 ·
yea but i dont want to pay another 80 to 120 dollars for another alignment, sometimes it will drive straight if I let go of the wheel. at any speeds. im confused. I may take it back there.
no take it back , i was just making a point that they dont care i guess, and obviously never test drove it after, u paid for something u didnt get , take it back ,,,,,,,,, i should of said NEXT TIME sorry my bad
here is some pictures, its been a while but im not the best at uploading stuff lol. Their only cell phone pics, tires are 295 BFG a/t. Looks alot better then stock IMO
Did your kit come with the rear blocks or seperate. Where did you get the kit from?
1 - 20 of 22 Posts
