So I installed my airdog 2-4G on my LML yesterday. The instructions that come with the kit are not right at all. The lml kit comes with GM quick connect hoses. No cutting metal lines are needed. The hoses are color coated. Two hoses look exactly the same though the inside connector is different. Your red line (all lines are blue but the label has a color code on it) is your to engine line. The smaller line is your return. The other, can't remember the color is your addiction line from the tank. DO NOT USE fuse 47. That fuse is all time hot!!! Use fuse number 45. It is the ignition on HAVE fuse. It should be a 10 amp fuse. I hooked my power wires straight to the battery though there is enough line to run to the alternator for a corrosion free connection. If you need any pictures please let me know. I hope this helps as with no proper instructions it becomes a little puzzling.
