Long story short I purchased an 05' with an engine knock and once torn down it ended up being a pounded out wrist pin bushing. I bought a used set of rods and pistons since the small end of the one rod was done but between the 2 sets (16 rods) I don't have 1, let alone 8 pin bushings that are within spec. That means I will be replacing all the bushings which looks like a fun task.
Before I go and design and make a tool to get them in is there any trick to handle the inward draft on the small end of an LLY rod? Is there a tool out there someone has a picture of that I can copy to get the job done? My assumption is if I try to press them in it will just deflect out and not align with the bore without some sort of guide. Thanks for any help that can be offered.
Just stock, otherwise I would just look at new rods. I bought a CTS but it was more for the gauges since I get nervous when I can't monitor a new build. I have no desire to get more power out of it or race it. That's what the car is for. :)
I always hate coming across thread that don't have solutions so here is what I did in case anyone else finds themselves in the same situation. It worked quite well. I found I had to make another piece for pressing them out since the ID of the old bushings is about .015" larger than the new ones so I needed a new tool that fit tighter. Also after pressing out the old bushings I hit the edge with a sanding cartridge to take the lip off otherwise it would shaft the new bushing as it went in.
