Intermittent tractor mode
173 Views 9 Replies 3 Participants Last post by  smore79
I have been having intermittent P2149/0203/0205/0208 code. It rarely happens and might be related to wet weather, possibly. I can hook up my scanner and delete the code then the truck will drive normally for long periods of time. I have replaced the injector connectors, I have ice picked them, I have looked for and not found any shorts in the wiring harness, I have insulated the harness above the FICM, I have opened up the FICM (it looks good). It will happen a few times within a single drive (2-3 times) I'll delete the codes and then it will run fine for a month or 2.
I am at a loss.
The truck is an LLY and it has a airdog lift pump. I will replace the filter, as soon as they arrive. The truck is tuned, has EFI Live and runs great besides. Any advice would be appreciated.
1 - 10 of 10 Posts
Maybe some help on the attachments
Reactions: 2
I will check it again. I can't figure it out. Thought I had this gremlin beat.
I just posted this on another thread.
Your FICM is on it's way out most likely. I've dealt with this 2 times already.
Good luck finding a replacement for a reasonable price unless you send yours off for refurbishment.
Reactions: 1
Thanks
Where did you send if to be refurbished?
Where would be a reputable place to buy a new one?
smore79 Thanks for all the intel with the attached post, that was a great breakdown. I'm so frustrated with this truck right now.
Reactions: 1
I still need to send my bad one off. Wasn't a top priority at the moment as I went straight into a head gasket job that ended up costing way more than expected.
I'm going to send the bad one to SIA Electronics - and hopefully the circuit board isn't bad.
You can search through eBay and junk yards, but you're going to shell some serious coin for a used one. The used one I bought was around 1700. Apparently GM doesn't make these and a few other modules anymore. Hopefully yours can be rebuilt.
Reactions: 1
Hang in there! Once it's all done you'll have piece of mind knowing you did all the work, and it was done right.
Reactions: 1
1 - 10 of 10 Posts
