1 - 9 of 9 Posts
I have a 2007.5 GMC Serria 2500HD LMM with the 6-speed Allison Transmission 4 wheel drive, the other day I went and picked up a mini excavator and was towing it home when I noticed something iv never noticed before. I stopped at a red light in town and when the light turned green I let off the breaks and pressed the accelerator. As the engine began to rev up to start moving from the stop, a loud clunk and then a jerk happened as I started moving. It only happens when I'm completely stoped and then start to move (1st gear only) when I have a heavy load. It doesn't do it if I dont completely stop, as in if I let it roll a little at like 1 or 2 mph and then go. It also doesn't happen when I'm unloaded or towing a light weight utility trailer and lawnmower. Would this be caused by a slip yoke needing lube or maybe the trans. Mount bolts being loose?
Do you have any vibrations at high at highway speeds?mite check carrier bearing if you have one.the rubber has a tendency to break apart .worth a look see.
Dam got interrupted by my grandson I didn't read that before i posted that LOL
Lol it's a straight aluminum drive shaft. I plan on crawling under these to check the trans mounts to see if there loose. I check the trans fluid and it's still bright red ( no dark color) and smells like new fluid. I've had the truck for 6 years and I do all my own maintenance. 262,000 miles and iv never experienced that. 🤔
Sounds like a problem with the trailer. I agree, if there’s a problem in the trans, the Allison controller plays no games. Almost always get a default and MIL.
Does it only do it when the one trailer is hooked up. Is the tongue loose on it or fluid level low
I feel your pain I know exactly what u are talking. About. If you haven't had the experience of the clunk and jerk nobody has a clue . I've experienced exactly what you talking about. I haven't figured it out either. But it's nothing to do with your trailer or ujoint. It's to drastic of a clunk and jerk. Mine feels like the things going to fall in the ground what ever it is. Or busy a housing.. good luck I never found mine
1 - 9 of 9 Posts
