Hi guys new to the form having issues with my throttle position sensor being way off on my 2009 Duramax Lmm at engine idle foot off throttle my throttle position sensor is reading 99% I have already replaced the complete accelerator pedal assembly and unplugged both batteries for 35 minutes and tried all the reset/relearn procedures posted online still reading 99% at idle I have Gm tech 2 scanner but don’t have laptop for Tis2000 software so only able to use just scanner mods done I have full hsp egr delete kit, 4” downpipe back exhaust no muffler ,efi live tunes , upgraded y bridge and 4” cold air intake , upgraded hot and cold side pipe , new turbo vane sensor , 3” downpipe, upgraded 2” passenger and driver up-pipes , upgraded head studs and new head gaskets please help anybody have any ideas why it’s ready 99% full throttle at idle ?? It idles fine my Air/fuel is off its reading 0.6-1 ratio and exhaust smell burns eyes..Before I uploaded my efi tunes I had the throttle position issues and exhaust smell and air/fuel ratio issues so it’s not tune issues also I metered out pedal sensors and harness
This is My Pedal Readings
* With harness unplugged from pedal key on engine off Both 5volt reference at plug tested C test 4.99 volts and D test 5 volts key on engine off APP sensor 1 with harness plugged into pedal key on engine off reads .56 volts and when pedal is pressed to floor it reads 2.36 volts App Senor 2 with harness plugged into pedal key on engine off it reads .28 volts and when pedal is pressed to floor it reads 1.07 volts
*With harness unplugged from pedal and key on engine off app sensor 1 reads 0 volts with harness unplugged from pedal key on engine off app sensor 2 reads 0 volts
With harness plugged into pedal key on engine off 5 volt Reference C reads 5 Volts and 5 Volt reference D reads 5 Volts
Key on engine off Ohms low reference F and sensor 1 reads 1.22 ohms then pedal pressed reads 1.92 ohms low reference A and sensor 2 reads 1.18 ohms and pedal pressed reads 1.72
