Did you replace all of the gaskets on your fuel return lines and o-rings are for certain on the high pressure side of the injectors? Did you clean all of the rust and crap off of the fuel lines before putting back on the new injectors?Everything torqued correctly? Those are about tho only places you will leak fuel. Did you have fuel in your oil prior and did you change it immediately after and now it is making oil again?
