It seems like the plate I got where the bolts go through wasn't wide enough. I might have messed up the gasket, So I guess i'm going to order a new gasket and go from there.
Pain in the ass.
Where did you get the plate? Unless you were rough with it the gasket should be ok it is a metal gasket. Try gettin the bolts tighter. Zacks had a whistle and we
tightened em more and it was good to go.
I got the plate from alligator I'll try to tighten them some more tonight you, Its when your driving down the high way and let off the gas you can hear it.
They All should be fine not really gonna get a bad one I don't think. They are all laser cut so if onefits they all will . Tolerances are tight with laser cutting. I know husker diesel plates fit 2 for 2 with me. But I'm sure alligator sold 100 of em and didn't have a "bad one"
had the same problem...just make sure it is properly seated.. tap it down there farther hammer and maybe a flat bladed screwdriver and tighten right up
