Get high or go Fast? 2015 ideas...?
  • Relift the LML with bigger wheels and tires + Cp3 Conversion
    Votes: 15 14.3%
  • Twins/Cp3 Conversion/Built trans from SDP
    Votes: 91 86.7%
  • Total voters
    105
  • Poll closed .
181 - 200 of 15472 Posts
Most Known Unknown
Sub'd to jwc's how to build a build thread thread! :)
Keep up the good work!!!
Looking at it on my computer now.
Looks like 4 LEDs in the center, with 2 additional ones about the second and fourth button.
Are you just looking to have the 4 center LEDs lit up?
If so, it looks like you can add p
I think I see that it's your sliding rear glass now that I'm on my computer...If you take that overhead console down can you please get a part number off of it for me.....
Most Known Unknown
Discussion Starter #187
welcome to the party :thumb
yes sir, looking to get them all lit up!
just get some 20 gauge wire and figure out where the power and ground need to touch then just solder them in?
im a noob with electrical!!
which PN do you need?
its got the sunroof controls and sliding glass :)
Nice Table of Contents :thumb I need to make mine longer lol...im Jelly
Most Known Unknown
Most Known Unknown
Discussion Starter #190 (Edited)
BIG Thanks to CCMATTHEWS for hooking me up with some stock LML Suspension!
- two spindles
- one diff crossmember
- 4 u bolts
- 2 front shocks
- 2 rear shocks
- frame ear (cut off for diff drop)
- 95% of the hardware
gonna get these cleaned up and take 'em to the cousins shop today :thumb
Iwrock,
Would you know how to wire this up? By any chance?
I have an idea to get some acrylic cut with a duramax logo or whatever and have these factory color LEDs be the back lighting
I can run wires for power and ground but wondering how to connect to the board..
Can't you order the pigtail that connects to the back of the switch cluster vs trying to solder to the board? I think having the direct plug in would be 1000x easier and it should have the illumination and ground wire already in the pigtail harness for the switch.
Most Known Unknown
Discussion Starter #192
hmm
if i did it that way, where would i wire everything else besides the dimmer, power and ground? (assuming there are more wires)
will it work if all the wires arent connected?
Most Known Unknown
Discussion Starter #193
hmm
Yeah, looking at that board, it looks like there are two pins that should power the 4 center LEDs.
hmm
Not sure about the LMLs but you should only need the ground and either just the illumination wire or illumination and dimmer wire. Should be very easy ad the light circuit should be seperate from all else.
Most Known Unknown
Yep. Those be the two pins needed.
JW - Do you have any old computer laying around? I think you can source the needed connector from one.
It looks like the third pin up from the bottom on the left row of pins is +12v (feeds the resistors), and the pin just above it (pin 4 up from the bottom on the left row) is ground.
I'd need a better pic to be sure, but from the posted pics, that looks about right.
Most Known Unknown
Discussion Starter #199
anything i could buy at radio shack?
i will find the piece and take more photos of it!!
