Get high or go Fast? 2015 ideas...?
  • Relift the LML with bigger wheels and tires + Cp3 Conversion
    Votes: 15 14.3%
  • Twins/Cp3 Conversion/Built trans from SDP
    Votes: 91 86.7%
  • Total voters
    105
  • Poll closed .
2461 - 2480 of 15477 Posts
Most Known Unknown
Most Known Unknown
I may be getting a new diesel. Either a Jetta TDI or a Cruze Diesel. Don't know yet.
Sent from my Galaxy LML
Cruze!
You can get EFI live tuning.
Most Known Unknown
Discussion Starter #2,468
thanks to Cayenne, i have a Down pipe coming my way!
Fc's old pipe i imagine :)
Most Known Unknown
Discussion Starter #2,470
nahhh over there on the passenger side, inside the frame rail, above the exhaust
on mine, there is a big open space of nothing + an un used OEM exhaust hanger
i mean, i might have some more room to push mine up, but to try something else and it works without issues? (now that would be pioneering right there!!) :)
Ah, gotcha, I know exactly where you're talking about. I considered mounting my air tank there in the future.
What do you think, incorporate the hanger or not? Drill/tap frame direct?
Most Known Unknown
Discussion Starter #2,472
nah that shits gonna be chopped off!
i would rather see about using existing bolts than make new holes :)
FML, i had a perfect picture of the area, and now i cant find it! But there should be plenty of room in there.....just need to visualize something and make it, would probably be pretty simple
anything is possible when your determined enough......except teleporting......that shit will never work!
Most Known Unknown
Discussion Starter #2,473
It's like,
Go outside and work on pulling the front axle out?
Or just hang out on the couch, hmmmmm
Most Known Unknown
Discussion Starter #2,475
Most Known Unknown
Discussion Starter #2,476 (Edited)
Dropping the front diff, part 1/2
So I went ahead and pulled the two straps off the front driveshaft and hung the shaft with a big zip tie to the hard lines directly above it (does anyone know for sure how to remove it from the transfer case?)
Removed the RCX skid plate as well
Most Known Unknown
Most Known Unknown
Discussion Starter #2,478
Misc pictures:
Drained fluid
What the leaking seal is doing nono
Detaching the wire from the plastic tab above the diff housing
Un bolting all the cv shaft bolts
Most Known Unknown
Discussion Starter #2,479
Also unhooked both batteries under the hood to keep any would be thief's from stealing it, and letting the front driveshaft go nuts :rofl
You guys are just awesome with these informative and easy to see threads, keep up the good work and keep the pics and expos coming. My wife will never understand my excitement over these forums. To me better than porn! I get a little raise out big hp and all the wrenching!!!
