Get high or go Fast? 2015 ideas...?
  • Relift the LML with bigger wheels and tires + Cp3 Conversion
    Votes: 15 14.3%
  • Twins/Cp3 Conversion/Built trans from SDP
    Votes: 91 86.7%
  • Total voters
    105
  • Poll closed .
2501 - 2520 of 15472 Posts
Most Known Unknown
Discussion Starter #2,501
Overwatch,
Think its possible to mount the lift pump in this area if the precautions are taken for the exhaust?
** beep boop bep**
modbot profile initializing........
profile loaded........
beginning assessment........
analysis complete, installation area deemed compatible........
initializing getofflazyassandactuallyfabthatcrap bot......
Most Known Unknown
Discussion Starter #2,503
Dropping the front diff, part 2/2
Started by removing all the cv axle bolts, and set them aside. Got a big zip tie per side and held the cv shafts out of my way, so they wouldn't be in my way
Unbolted 5x bolts that held the diff up, and dropped it down.....didn't need to lift the truck at all to gain clearance from the sub frame pieces
Most Known Unknown
Discussion Starter #2,505
Took a couple misc photos of the bottom of the motor, whatever paint they use blows donkey balls
You can see the hardware used to hold the diff and axle tube to the 3x diff drop brackets associated with NTBD lifts
Also one last photo, of the......emptiness......flash was on nono
Most Known Unknown
Most Known Unknown
Discussion Starter #2,507
** beep boop bep**
Maybe just unbolt the exhaust hanger, and make the holes bigger if needed, to work with existing brackets, and use stronger/bigger bolts :)
Then just make sure its strong enough, if it were me I would try to utilize another bolt in the area to offer a different....approach to supporting the unit on a different axis
Get crackin on it :thumb
Most Known Unknown
Discussion Starter #2,508 (Edited)
Nah
Second thought, just make a plate that touches all three bolts you see in the photo (two for exhaust hanger and one for DPF sensor) and open the holes if needed and space it off the frame and attaché the fass bracket, but only if you can hold backup on the frame bolts.......I didn't check :( probably not soooo something will have to be figured out!
Most Known Unknown
Discussion Starter #2,510
Just came here to say
In the mighty words of Erick "someone get me a fire hose cause my duramax is smokin'"
:rofl
He should be good now, he ditched motorops :thumb
Nah
This is what I'm gonna wind up doing, but won't use any of the stock brackets. Will render it tomorrow at work and save the file for others to use in the future (assuming it works of course).
Hurry up. I just got my FASS in, let's doing something cool.
Sent from my Galaxy LML
Finally! Wheels on!
Most Known Unknown
Discussion Starter #2,514 (Edited)
eager to see what you come up with!
our plasma got stolen at work, this past week...... so if i make anything i have to cut everything with a die grinder or a sawzall nono
making a simple 1/4" thick steel skid plate for Cayenne, and right when i get ready to work on it, the good shit from work comes up missing :eek:
just make room in the engine bay :)
move a battery or something :rof
knew you'd like that :)
i think a red SRW LML with drop shackles and backed off adjuster bolts on a set of black 22s looks pimmmmppppppp!!
Finally! Wheels on!
That's what I've been thinking about the dually, except not black. The problem is finding 22 inch tires that are load rated correctly and arent 35 inch.
Most Known Unknown
Discussion Starter #2,516
Whats wrong with 35's?!? :stickpoke
Well I am mounting the FASS in the wheel well. I wanna hit the track tomorrow night and Northwest OHV Park on Sunday. I will remount it later. Stock location for now.
Most Known Unknown
Finally! Wheels on!
I don't want to fender mod nor do I want to re gear. Remember I'm one of the few who use their truck for its intended purpose and I don't mean mall crawling JDub
Sent from AutoGuide.com App
