Get high or go Fast? 2015 ideas...?
  • Relift the LML with bigger wheels and tires + Cp3 Conversion
    Votes: 15 14.3%
  • Twins/Cp3 Conversion/Built trans from SDP
    Votes: 91 86.7%
  • Total voters
    105
  • Poll closed .
4581 - 4600 of 15477 Posts
Most Known Unknown
hmmmm
i'll just end up slicing it on either side of the leaf spring end and maybe hit it with a body saw :)
removing the spare tire makes this alot easier too, as for as the initial installation....i found that out REAL quick!
but i was also removing sulastics at the same time...
all the bolts once pushed through half way or so had to be backed out to be removed....since there is so much tension nono
I just finished cutting the seam almost completely off and the crazy springs are still hard up against the bed... Does that have anything to do with the fact that I only have 17s? Would a larger rim solve the issue? I'm bout ready jus to let the springs clearance themselves by bendin the bed however they want to.:help
Most Known Unknown
Discussion Starter #4,584
Time to ditch the springs and get air ride :)
But I'm curious as well...
Nobody else acts like it's a big deal, why me??? :cookoo[1]::rof
Most Known Unknown
Discussion Starter #4,587
Is your bed unbolted at the rear and it still has pressure on it?
Now I'm REALLY curious what happens after I trim mine..
No I'm all bolted back up... Thinking about maybe tryin to space the bed up a little bit. It's tight enough against the bed to make a bump in the bed floor.
Most Known Unknown
Not extremely fond of that idea...
Most Known Unknown
Discussion Starter #4,591
well,
figured since it will be a little while before i get everything all situated with the truck, that i would go ahead and post my pictures for the reverse lights and license plate bulbs i installed from Diode Dynamics
here was my order details :)
Item Sku Qty Subtotal
1999-2013 Chevrolet Silverado Backup LEDs (pair)
Bulb Model
SMD27 (205 lumens) 2x3156_SMD27W-bckup 1 $30.00
1999-2013 Chevrolet Silverado License Plate LEDs (pair)
Color
Cool White
Bulb Model
SMD2 (24 lumens) 2x194_SMD2W-lic1 1 $8.00
Subtotal $38.00
Shipping & Handling $5.00
Discount (Point Redemption, July4) -$3.80
Points Earned 38 Diode Points
Grand Total $39.20
since the truck is still without power until its ready to go to alignment, i dont have pictures yet of them lit up, but i will...and i'll make sure its in the table of contents :) (by that time i'll have the fogs all hooked up and show them all at the same time!)
first we start out with the bulbs themselves!
Most Known Unknown
Discussion Starter #4,592
then we start with removing the 2x screws that hold the tail light in, on the inside of the tailgate area
of course it was dirty.....not sure how.....you know, because mall crawler :rolleyes:
Most Known Unknown
Most Known Unknown
Discussion Starter #4,594
put the stock ones back in the case, just in case
starting to remove these ol' ass stock bulbs
Most Known Unknown
