Get high or go Fast? 2015 ideas...?
  • Relift the LML with bigger wheels and tires + Cp3 Conversion
    Votes: 15 14.3%
  • Twins/Cp3 Conversion/Built trans from SDP
    Votes: 91 86.7%
  • Total voters
    105
  • Poll closed .
5341 - 5360 of 15477 Posts
unknown known most
I was looking for that quote too erick! I was lost for a min..lol
Most Known Unknown
Discussion Starter #5,344
so my twin steering stabilizers came in today
and honestly, i'm very surprised the centerlink stud showed up with both of them!
thats usually hit or miss nono
they sure are pretty :)
Most Known Unknown
Discussion Starter #5,345
unknown known most
Did u say those were going to be put on today? Lol
My phone is shot. Top button dont work, battery barely last a day, plus its messin with my email.
I get everything but forum mail. That goes to junk! :rofl
This is just since last night!
just send him my paycheck and make the truck super dooper fast?!?
I wish I could just drive my truck to him, hand I'm $300 to just flash the tow tune on, sawzall my exhaust off in his parking lot, drive home lol.
Most Known Unknown
Discussion Starter #5,349
i need to get under there and measure some things :)
i know i can get a single in there for a temporary setup, but think i will look at the Skyjacker pieces i removed and see about retrofitting them or coming up with something new that will work
they require 4" of front end lift because the outer brackets "ears" will hit the LCA when its moving
and since nobody has a dual kit that works similar to the skyjacker kit, i will need to figure something out
got plenty of 1/4" steel plate at work, the only downside is how it attaches to the centerlink......i could mimic skyjackers way on how it mounts but its not guaranteed NOT to roll on the centerlink (which in theory doesnt matter) but i'd like it to have a bar come off the centerlink stud area and with rubber bushings (like those on the centerlink) attached AROUND the centerlink,...and have a drop down bracket
that way its not metal on metal on the freshly powdercoated centerlink....and it would be rubber....maybe even grooved with a grease fitting :rof
should be fun..if i have time
Most Known Unknown
Discussion Starter #5,350
soak it up while it lasts :rofl
how far away are you from him?
unknown known most
I got faith u will "figure" something out Jeff, you always have ha
Just like 1100 miles lmao it truly would cost just about the same either way, but if I go down to LA, or my grandmother were to pass through there, trying to hold off right now.
Wait til I can do a few goodies at once.
Most Known Unknown
Discussion Starter #5,354 (Edited)
here is me ripping the ugly piece off the cab that holds the fender up...
my advice, if anyone chooses to do this.....trace the outline of this piece on the cab before removing... i learned real quick how fun it was to line a fender up with this piece loose nono
i painted the driverside bracket too, but did not install....i wont do that until the fenders are ready, again,,......even though the driverside one was painted, where as the passenger side one wasnt?!?!?!?!
7mm holds the antenna on
13mm holds the bracket on
T15 torque holds the plastic flap on (there is a bolt behind the flap)
Most Known Unknown
Discussion Starter #5,355 (Edited)
driverside getting loosened and removed
cleaned up the areas with some quick wax and a microfiber
even the battery tray, firewall, and whatever else was exposed
Most Known Unknown
Discussion Starter #5,356
thats as clean as it gets before going abrasive
got the piece cleaned and painted
2nd picture is of it drying, hanging from the front of the truck :)
remove the 2nd battery tray to make sure its not in your way trying to hang the fender
Most Known Unknown
Discussion Starter #5,357 (Edited)
then BAM
you put your not so perfect almost colormatched fender on!!
hopefully the painter has a rough quote for me today or tomorrow, i need to drop all this stuff off
seriously...its bugging me
at least it can clear a much bigger tire :rolleyes:
btw,
the gaps arent set up yet
i gave up once i noticed the color was off :rof
Most Known Unknown
Discussion Starter #5,358 (Edited)
btw
i'm not mad at my cousin
he can only do so much, and it was free :(
he did a great job with the body work, and made an awesome shine to a white fender, but even though the paint code was the same....it didnt match Downerrr
no worries :thumb
he'll still paint the blue truck, no colormatching there :)
Looks sick! Congrats on getting em done, and lookin factory!
