Get high or go Fast? 2015 ideas...?
  • Relift the LML with bigger wheels and tires + Cp3 Conversion
    Votes: 15 14.3%
  • Twins/Cp3 Conversion/Built trans from SDP
    Votes: 91 86.7%
41 - 60 of 15505 Posts
Sub'd for JDub!
got damn it JWC....
Subbed
I had the wrap on my goat, it makes it easy! Jus pull it off, shake it, rinse if nec...and boom.
When you doin the ELF mod??
Most Known Unknown
Discussion Starter · #56 ·
I put the wrap on @ 19650 miles, and the truck currently has 23432 so i will check it this weekend to see the progress :)
as for the ELF Mod, i need to make a few decisions first
do i want to go to stock?
do i want to drop the lift some more for flat lined CV's?
do i want to get 22x12s?
do i want to keep the same wheels and get 37s?
decisions decisions :cookoo[1]:
i know whats going to happen, i will drop (modify) the lift (switch from 3" to 2" block) and upgrade to 22x12 and if i need to modify the fenders, then its on like donkey kong :thumb
Most Known Unknown
Discussion Starter · #57 · (Edited)
Moving forward with the Nicktane Cat Adapter and filter change :thumb
ordered my adapter and a few spare filters from Mad Jack Racing!
and when i was done i had some priming issue, and after talking with MudDoc i was set on what i needed to do, forgot about the bleeder screw :cookoo[1]:
and i had the wife cranking as i was priming, ever since that day i havent had any issues with losing prime :cool:
That makes me sick! I've got about 90k on my truck already and wish it was a lot lower like yours is..
But anyway good write up so far.
Subbin
