Get high or go Fast? 2015 ideas...?
  • Relift the LML with bigger wheels and tires + Cp3 Conversion
    Votes: 15 14.3%
  • Twins/Cp3 Conversion/Built trans from SDP
    Votes: 91 86.7%
  • Total voters
    105
  • Poll closed .
61 - 80 of 15477 Posts
Most Known Unknown
Discussion Starter #61
i dont drive it alot, only when its nice out or if i need to haul something,......or go to a family get together :rofl
thats what the gasser is for!! (gasser has like 102k, and still running strong) :)
Most Known Unknown
Discussion Starter #62 (Edited)
so then i wanted to lower the lift down
there wasn't anything wrong with it. I didn't have any weird vibrations but i wanted to upgrade the shocks anyway to FOX, since my front left was dead. Plus as time goes by i saw more and more leveled guys with the same size tire, so i was like "hmm that sucks" so i did something about it, and started playing :bd03
it was trial and error as you can see, i totally forgot about the jounces when i dropped it down and was wondering why it rode sooooo bad
live and learn right :rolleyes:
before lowering
after lowering
jounces before lowering
jounces after lowering
Most Known Unknown
Discussion Starter #63
then i thought to myself, time to cut these bad boys in half and see what happens
still rode like crap :)
then i pulled the jounce, just to make sure it bottomed out while driving, and then it began :thumb
Most Known Unknown
Discussion Starter #66
so since i had a dead RCX shock, i upgraded to the foxes :thumb
since my lift was basically where i wanted it to be, i did some measuring. You MUST measure if you want to ensure you order the correct stuff. these "PACKAGES" people sell will not always work for us guys that have modified lifts, or whatever
so i talked to Tommy @ PolyPerformance.com and after going out to my truck a few times to measure stuff we came to the conclusion on what models to buy
i ordered:
(FRONT) FOX-980-24-683 2 Fox Universal Eyelet 2.0 IFP Performance Shock 8.5" Stroke
Mounting : eyelet - eyelet
Stroke : 8.5"
Extended: 23.425"
Collapsed: 14.925
my front mounts are 19.5" apart so i will be right in the middle, and have the correct mount on top and bottom!
(REAR) FOX-980-24-659 2 Fox Performance Series IFP for Chevy Trucks, Rear, 4-6" Lift
Most Known Unknown
Discussion Starter #68
more
the upper RCX mount that was supplied with the lift needed to be trimmed a little as you can see
the height of the upper shock mount on the FOX was a little too tall for the RCX mount, so here comes the grinder!
didnt need any metal on metal contact :thumb
Most Known Unknown
Discussion Starter #70
got bored one day and pulled the inner fender liners off, cleaned the inner fenders with some microfiber towels and quick wax, and cleaned the "top" of the motor up and the bottom side of the hood!
also pulled the DEF fill tube out, while i was in there :thumb
Most Known Unknown
Discussion Starter #72
well one day i decided to sell my DDM HID kit to a guy at work for his stock H11 and 5202 bulbs plus some cash
since he hard wired his fogs in like i did, he gave me his pigtails off the fog lights!!!!!
and i had the head lights done on day one, but i got lazy and never got around to hook the fogs up, so then i did :)
before with the valance, then after! (thanks to WildChevys for yelling at me for still having it installed!!)
Most Known Unknown
Discussion Starter #73 (Edited)
did the resonator delete kit
took like 8 minutes!
and on one of those really really hot days we had, the adhesive on the back of this rear sliding glass stop apparently it was too much to bear :( and slid my tint off :cookoo[1]: (so i used a rear view mirror adhesive kit and put it back, but still havent fixed the tint, coming soon!)
and a few mall crawlin' pics!
sub'd for moar mall crawling adventures.
Most Known Unknown
Discussion Starter #78 (Edited)
so here goes the install with the Skyjacker dual steering stabilizer kit
that i modified, to work with the Cognito supports. If you do not modify it, it will not work
maybe i should go into business and make these...... :rolleyes:
there is a much more detailed write up in the linked thread in my sig :thumb
