Get high or go Fast? 2015 ideas...?
  • Relift the LML with bigger wheels and tires + Cp3 Conversion
    Votes: 15 14.3%
  • Twins/Cp3 Conversion/Built trans from SDP
    Votes: 91 86.7%
  • Total voters
    105
  • Poll closed .
8021 - 8040 of 15477 Posts
5 yr note at 15% interest would be $18K+ in interest for the duration of the note
Most Known Unknown
Discussion Starter #8,022
Screw that!
Sorry guys :rof
I was running simple numbers....
didnt go that route with the LML
Well 72 month and total financed was almost 41k. I was only financing about 23 of it.
Most Known Unknown
Most Known Unknown
Discussion Starter #8,025
Guess ill keep cooking my meth, hitting up old lady's for their purses, and running a chop shop so I can stay away from banks
:D
Because 'Murica
:D
Because 'Murica
Lmao you hiring any helpers?
Finally! Wheels on!
How to know when your truck is too tall
And how to know you are a real redneck
When all your tools are back at the other house and you are halfway through the oil change before you realize it. 4 inch screw clamp and a nail bar. FTW! And why I'll miss the 12 inch lift when it's gone
Didn't even have to get under it. Just kneel down and lean in and flip the fumoto. Kinda sucks that the oil filter is too far off the ground to get both hands on it while laying flat, though
Hahaha!! Thats awesome! Jus dig you a lil hole out there and you can walk under it to change it!
Back to the plasma cutter. I would get the bigger one. The more expensive one is a lot more machine. The smaller machine has an onboard compressor that you are paying for. I like the separate air compressor option, less to go wrong with the plasma as a unit. Clean dry air is also important and will help your tips last longer. With a built in compressor you will get what goes in form the air without the benefits of a tank for volume. The volume tank allows the air to cool and the water to condense out. The thinner the rating of cut capacity the slower you will have to go and the more heat is transferred into your material creating warpage. The small one is rated to cut mild steel up to 1/8in. @ 10in. per minute; 1/4in. mild steel @ 3in. per minute. That is awful slow. My plasma for instance is rated to 1/4" steel at a rate of 96" per min. You asked if the smaller one will slow you down, that rating will tell ya. Also look at the power requirement of each unit and make sure you have it or can get it wired.
You know what you do the best. Age has taught me buy once cry once. I have bought several things in my time thinking it was good or big enough only to have to spent the money I saved plus the money I first laid out to get the one I should have bought the first time.
Short radius garage door track, there is also is a set of arms that use the existing long radius track to raise the door flush with header, had both types on one of my houses. The second time was short radius track after I hit the first door when the power was out one morning before leaving, spring did not hold it open completely and I hit the door with the rack on the truck.
Headroom, door frame, and calculation | Architects | Garaga
Agreed 100%! :thumb
Look at adjusting the door so it will go all the way up. It might take a longer track or door opener extension kt.
Not a big deal!
Hes lowering the truck soon!!
unknown known most
That's not redneck tex....that's called thinking outside the box!! Ha u might need to put a patent on that tool!!!
Finally! Wheels on!
Lol. As it sits now it would hit the header even if the door were open all the way. It just needs the tension adjusted
05 3500, you are correct. Buy once cry once. I forgot. Seems like every time I try to save money it costs me more
Off topic, what do you guys think about the aluminum frame on the new F250? and do you think GM will follow in the next few years?
