Get high or go Fast? 2015 ideas...?
  • Relift the LML with bigger wheels and tires + Cp3 Conversion
    Votes: 15 14.3%
  • Twins/Cp3 Conversion/Built trans from SDP
    Votes: 91 86.7%
  • Total voters
    105
  • Poll closed .
9081 - 9100 of 15477 Posts
Finally! Wheels on!
hmmm, maybe. Just maybe.
Most Known Unknown
Discussion Starter #9,082
Raptor liner is on order
Ordering wheels and maybe a tire this weekend or first of next week, but for sure the wheels!
We closed on the house today and we start moving in this weekend
So far the garage gives me 3' extra to work with while the LML is inside (old garage wouldn't even fit gray gasser)
We discussed yesterday what we needed the contractors to do before we officially moved in (I.e, granite, 2nd deck, 220 outlet for the garage, and fitting a double oven in the kitchen, etc etc), but everything is on schedule and going good!
I should be moving the garage in this weekend as well as picking up new furniture in the woodlands. Movers will be moving the big storage unit with everything else we have, cuz I ain't doing it!
Sweet!! I still need to figure out my cts mount. I didnt reinstall it after the new dash. Dont like the mount i had.
unknown known most
Sometimes a bigger hole is better for more room.....I said sometimes......
Finally! Wheels on!
Most Known Unknown
Finally! Wheels on!
So all we'll need is my little sheet metal bender, some thick paper to make a template for the bolt holes in the back of the dash, a sharpie, tin snips, some 1/8 inch and 3/16 drill bits, pop rivets, and the tools to remove the lower knee kick panel.
Oh, and the whiskey...mustnt forget the whiskey....
I'll bring the stuff we need back from the weekend place. I already have the hard part done, which is the wiring.
You have to have these to make the CTS sit closer to the dash. They are just extension cords if you will.
If you look closely you can see the notch I mentioned on the phone. Probably can do it without notching if you think it's too visible but we'll have to carefully arrange the wires so they are only one layer since here I put the two pigtails on top of each other. The black dash probably makes it harder to see.
Sounds great! Look forward. Maybe jeff and erick will make a appearance as well...
Most Known Unknown
Discussion Starter #9,090
If we have enough heads up we can get tmoore777 to meet up too :)
Sounds good to me. We should know a good date after this weekend. We could all meet up at my place knock out my cts mount real quick and then do whatever, could grill and hang out by the pool or whatever.
Most Known Unknown
Finally! Wheels on!
Yeah. One weekend we need a guys weekend and y'all can come up here.
Little fire and whiskey after building a bridge across the wet weather creek.
Finally! Wheels on!
Yeah. 2x12x20ft treated are heavy as a mofo. I'm a worn out puppy.
Finally! Wheels on!
Old no 7 and coke zero.
Yeah buddy. Love me some of that.
Most Known Unknown
Discussion Starter #9,099
Had something hanging down under the bumper :eek:hno
So I chopped it off
Also used the trailer to transport stuff from the current residence to the new/final residence :)
LML puttin' n work!
Put in a sign I saved from work :)
Most Known Unknown
Discussion Starter #9,100 (Edited)
Truck fits, and could definitely have a little more clearance with the drop hitch removed :thinkk
Idk where I was getting 3' from earlier, must have been the shoes...vs a tape measure
View from the kitchen
