Get high or go Fast? 2015 ideas...?
  • Relift the LML with bigger wheels and tires + Cp3 Conversion
    Votes: 15 14.3%
  • Twins/Cp3 Conversion/Built trans from SDP
    Votes: 91 86.7%
  • Total voters
    105
  • Poll closed .
81 - 100 of 15477 Posts
Most Known Unknown
Discussion Starter #87 (Edited)
well
its time to upgrade the tie rods :)
i emailed Tony @ FFR Fabrication and told him my idea. I didnt need some 1.5" OD tubing for all the mall crawling that i do, so i stuck with his standard 1" OD kit
it was an opportunity for him to start making kits for the LML platform, and for me to get the first kit by him at a cheaper cost :thumb $$$ :thumb
i wont go into details on what it took to get these to work on the LML platform, but i can say he figured it out and can now sell ready made kits :thumb (iirc his kits are $240 shipped to your door)
needless to say, he hit the ball outta the park with these, because they are way nicer than any stock rods, and not "MARKED UP" like ones you would find from cognito :)
i was the guinea pig, and i loved it :)
Most Known Unknown
Discussion Starter #93 (Edited)
well after Halloween i installed hose clamps on both trucks
some lady was walking up with her kids, so they could get candy (we were in the driveway passing out candy) (we don't need a van like TheStepChild)
and she was going on about how she liked the truck and how its always clean, etc etc etc, and then said "aren't you the guy that just had your wheels stolen?" because i had the stock 20s off the gray gasser stolen :(
and i said "Yes Maem" and she told me the easiest way to help deter thieves besides shooting their heads off, is to put hose clamps and turn it to where the bolt head is on the inside of the tailgate metal, and torque the shit out of it!
so thats what i did :)
got bored and checked the rear diff magnet for shavings, and this is what i got after about 21k miles
got under the truck to look around and saw this.
i still need to order that sensor!!
went to 4 wheel parts and bought two new lug nut keys. I lost the one i had previously, its probably hidden really well in the truck :rofl
Most Known Unknown
Discussion Starter #94
got some free time, and ordered a rough country torsion bar unloading tool
and when it came in, i pulled the front suspension apart
pulled the torsion bar bracket out, and sectioned a little more out of it
Jwc i am confused about the hose clamp solution.... What does it do?
Most Known Unknown
Discussion Starter #96
got some pieces painted and installed
put new lower ball joints in while it was down. I broke the platforms off the torsion bar bracket, cleaned them up, re-welded them, and instead of grinding the welds i used Quick Steel (in a tube) and applied it, and used a piece of straight cardboard to even up the lines and make indentations in it, for flare :thumb
also painted the stock UCA's that will be installed sometime soon
Most Known Unknown
Discussion Starter #97
then came the cold weather, that doesnt seem to want to leave!
so with the CV shaft out, i used a scotch brite pad, cleaned it up and sprayed it black. It also had a little dimple in the rubber boot so i fixed that as well.
Most Known Unknown
Discussion Starter #98
to take your tailgate off, you must "LIFT" up on the passenger side, and "SLIDE" it to the right to remove the tailgate
if you put a hose clamp around the half circle of the bedside and the solid circle of the tailgate, it no longer has a way to be "lifted out" of its slot, which keeps your from "sliding" it to the right and running off!!
go check out your truck and you will see exactly what i'm talking about!!
its cheap and could save your tailgate :thumb
To help prevent anybody from stealing fuel or worse adding some shit to your tank get a locking fuel cap.
Most Known Unknown
Discussion Starter #100
due to the cold i decided, being outside just wasnt for me (non stop rain and cold) :thumb
so i stayed in the garage and prepped the dual pod pillar i received from a member on here
i used some Bull Dog adhesive promotor (few light coats) then sprayed some of the factory match Tan paint from Alligator Performance (its PN# CB333), again with multiple light coats
propped it on a few jack stands and went to town :thumb
