Get high or go Fast? 2015 ideas...?
  • Relift the LML with bigger wheels and tires + Cp3 Conversion
    Votes: 15 14.3%
  • Twins/Cp3 Conversion/Built trans from SDP
    Votes: 91 86.7%
  • Total voters
    105
  • Poll closed .
1081 - 1100 of 15477 Posts
How are you going to keep the mount from rotating?
save the geese!
Most Known Unknown
Discussion Starter #1,083
Did you see the top stud :) it's bolted twice in a horizontal and vertical way before dropping down
The lower shock mount won't move if doubled up with one stud
Interesting way to do it.
I wouldn't mind mocking if up, if there was any way that this would work on my LBZ.
Most Known Unknown
Discussion Starter #1,085
lets build it Justin :thumb
only issue would be, for both 01-10 & 11-15 is the shocks would have to be a tad shorter, unless its ok to run roughly 1 /1.5" less stroke *depending on how much shock stroke is actually utilized!
but thats when you look at how much is the suspension really going to compress vs how much shock stroke is actually happening, then you gotta break the grease out again and see how much stroke is going on :)
Most Known Unknown
Most Known Unknown
Most Known Unknown
Most Known Unknown
Discussion Starter #1,091
resistors came in for the LED fog light bulbs
just need to get them installed now
Finally! Wheels on!
Found a solution for Redneck, even fits his name. Lol
Sent from GS4.
Yep and I could use the stack as a rod holder!
Jdub, I'm wondering if the lower mount with stud would cause the stud to bend without being supported on one end. Could weld a single bracket on each side of the axle to make a twin mount. I'll have to crawl under and have a look. The dually has a little less real estate to work with, especially with the air bags.
Eric, the air bumps are cool but the larger problem is rebound. I can work the compression with the bag PSI.
Thanks for the thoughts. Good ideas. You'll make a shock engineer before long JDub
I was planning on rotating the rear shock mounts so they don't hanged down. Just as others have done. After I get my front end squared away and figure out what I'm going to do then I'll tackle that.
Put this in the wrong thread.
Hey let's go to Royal Purple Raceway Friday night and beat up on some imports.
Sent from GS4.
Most Known Unknown
Discussion Starter #1,095
actually...... i am working on a dampening idea..
but back to your idea :)
i put these on the front AND rear of my blue project truck
for those nice and shiny QA1's :thumb
Finally! Wheels on!
You may be right. Was looking at some aftermarket dual shock set ups and they seem to follow that thought. Just wonder how many of these mall crawlers actually work the suspension hard for thousands of miles with 4k plus in the bed.
Most Known Unknown
Discussion Starter #1,097 (Edited)
Only one way to find out :)
There are easier ways, I was just trying to pitch one or two that didn't require welding or cutting or drilling :)
Finally! Wheels on!
Whoo hoo, the Insight CTS shipped today! Cant wait
Most Known Unknown
Discussion Starter #1,099
Got an idea for a different style dash mount for the CTS...
Should I break out the pen and pad and pitch it to you :rof :rof :rof
Do tell....
Sent Screaming Through The Turbo of My Duramax
