Get high or go Fast? 2015 ideas...?
  • Relift the LML with bigger wheels and tires + Cp3 Conversion
    Votes: 15 14.3%
  • Twins/Cp3 Conversion/Built trans from SDP
    Votes: 91 86.7%
  • Total voters
    105
  • Poll closed .
15101 - 15120 of 15472 Posts
Nope total plug and play on glass and forward blinkers. The forward blinkers are not clearance lights as well, is what I meant. You can wire em up tho.
The reverse leds come with taps to install.
They definitely look great. No complaints there. A wee bit shaky at high speeds. The glass is shaky not the housings themselves.
I'd buy again. If I could get OEM for double I'd thInk it was worth it. Lower glass has great field of view
Most Known Unknown
Discussion Starter #15,103
Well crap, you sold me!
Gonna get them on order today, and as for glass shaking...that's no big deal unless it's horrible then there are ways to absorb it :)
Haha I am in sales afterall.
Yeah I was gonna do something after the winter to make em steady.
Oh yeah... blinker light on glass on drivers side, top led bulb was out from the get go. I don't really care though
You guys have some pictures?
I see them for the exact price Oscy, figured why not
I really just want heayed, power adjustment, and the normal glass blinker
You said the wiring would have to change to make the glass blinker work?
Like oscyjack said, you really can't beat them for the price and everything was plug and play except for the reverse lights. I just wired them to a small rocker switch in the cab so i can turn them on whenever I want. I can get some pictures when I get home from work tonight.
Most Known Unknown
Discussion Starter #15,107
hey Justin,
do those chrome caps pop off?
don't have any chrome on the truck, and screw plastidip
hey Justin,
07-13 Silverado Sierra Black Power+Heated+Smoke LED Turn Signal Towing mirrors
Search that on ebay, you can buy them in all black with a smoked turn signal lens. But it is also my understanding that the chrome covers will pop off but will need replaced with black covers.
Most Known Unknown
Discussion Starter #15,111
the new mirrors will be here tomorrow!
so my thoughts..
A. instead of rocking the chrome, pop the pieces, plastidip them black though im not a fan of the stuff, but might be good that high up, rock that until i get the front clip repainted, and have them painted at the same time, and they wont be textured plastic.
B. didnt get that far
Most Known Unknown
Discussion Starter #15,113
My logic behind it was to get the chrome ones since they're smooth.., that way when i get from my clip repainted i can get them painted at the same time, and the time spent sanding on the textured black plastic caps wouldn't be an issue.
i can plastidip them satin black and rock them like that (Since they would match the wheels N stuff) and when i go to repaint, i peel it all off and get everything sprayed together
:D
Most Known Unknown
Discussion Starter #15,114
so the mirrors are here, been working on the yard lately taking advantage of the rainless weather, and also the lift and 37s are gone and sold off!
Finally! Wheels on!
Needs portal axles
Most Known Unknown
Discussion Starter #15,118 (Edited)
so yesterday evening i went ahead and installed the tow mirrors i bought off ebay, $145 shipped, and so far i'm enjoying them!
i don't have the courtesy lights hooked up yet, but after reading a little more, they won't be hard at all to make work!
i started with the driverside first, but the pictures i lay out in here will be the passenger side first, that way if anyone needs a pointer (really easy install) the cleaner side will be shown first :)
first you remove the panel behind the door handle, and then the one under the arm rest.
everything is 10mm, an extension is required
don't forget the panel on the backside of the mirror
Most Known Unknown
Discussion Starter #15,119
cushion for the pushin' :D
razor blade to pop the cover off, there is a threaded rod down there that this sits on, and the small cover wedges around the threads
you dont need to remove the door panel, just mainly pop it free on the mirror side so you can unplug the wires
sockets face downward
Most Known Unknown
Discussion Starter #15,120
next is the 3x 10mm to remove the mirror
plug
verifying the new one and the old one match
there is a smaller plug with a long bundle of wire included, that is for the courtesy lighting
snap the new one in and bolt it down
