Get high or go Fast? 2015 ideas...?
  • Relift the LML with bigger wheels and tires + Cp3 Conversion
    Votes: 15 14.3%
  • Twins/Cp3 Conversion/Built trans from SDP
    Votes: 91 86.7%
  • Total voters
    105
  • Poll closed .
15281 - 15300 of 15477 Posts
Most Known Unknown
Discussion Starter #15,281
The property is pie shaped
GOT PLENTY of room back there
Could probably fit a 60x60 but, I wouldn't want to pay for the slab!
Finally! Wheels on!
Concrete is about $121 a yard delivered. If you build your own forms and bust your own rebar, you just need a few able bodied friends to rake and screed and float. You can rent the tools. 5 inch slab, 40x60 would run you about $4500-$5000 for the concrete plus the cost of beer or whiskey for your friends to help.
Erecting a metal building is easy if you don't engineer it and have to have permits and stamps. You can start by pouring a 40x30 and then add on to it later and add the other.
you can simple span 30 ft with C purlin but if you go 40ft then you have to have the big steel beams that cost significantly more. If you can live with 30 ft then you can make it as long as you like, just keep adding on. Small mig welder and some self tapping screws and you can go to town.
My shop is 30x30 and I intend to add another 30x30 on to it. The second half will be taller to accommodate a lift..
Plan for possible future uses and whatever size you go, make sure you make it TALL enough.
Put the peak of the roof in the correct direction to be able to make it longer at some time in the future.
Most Known Unknown
Discussion Starter #15,284 (Edited)
Put new shocks on the old truck
5100s from Bilstein again, and it definitely made a difference up front, one of mine if not both weren't working that good up front, for the longest
HmmMMmm How many miles on the old shock set?
Have over 550,000 miles on my 2010 fronts Rancho 9000s
Most Known Unknown
Discussion Starter #15,286 (Edited)
Welded stainless today with nonmag elite wire, with 20-30 crushed carbide
First time, and it turned out in spec and visually very nice :)
Had water circulating in the ID and preheat was a whopping 100 degrees with an interpass heat range of 100-400, so I welded the first one, saw an increase of 170 degrees, so the next batch of 3 bands I welded two, let it step to the 3rd, stopped it, let it cool, and knocked number 3 out
Next up is getting the machine shop to machine me two pieces that go together so I can start laying beads down in a groove so I can get into stub welding, so the district and myself can make more money
#hardbanderslife
#learningnewthings
#jobsecurity
Water was off but there's a probe with hose in the box connection so it would pass through and fall back into the trash can where the submerged pump would work it's magic and re-circulate
Most Known Unknown
Discussion Starter #15,287 (Edited)
so this past weekend i knocked out getting the chipped front end and flaking rear bumper caps replaced with chrome pieces
the main metal bumper came as a skin and everything structural on the backside had to be swapped over
Most Known Unknown
Discussion Starter #15,288 (Edited)
these two pieces along with a skinny brace in the 3rd picture were scuffed and sprayed with rustoleum undercoating
these two pieces in particular can be seen through the center opening so i wanted a uniform coating, not any white flaking paint
Most Known Unknown
Most Known Unknown
Discussion Starter #15,292 (Edited)
then it was time to wash this mofo, its been neglected for about 3 months or so due to rain and cold and more rain and cold
Most Known Unknown
Discussion Starter #15,293 (Edited)
finally clean!
added a pair of new 4.5T shackles to the receiver
then it was time to change the trans fluid with Transynd, the truck has 85k on it currently and i had some spare time!
Most Known Unknown
Discussion Starter #15,294
started with the spin on filter, not forgetting to swap the magnet over before reinstalling the new filter
also added a spare filtermag to it as well
Most Known Unknown
Discussion Starter #15,295
then i added 1.5 gallons and took it for a spin to get it hot before checking it multiple times
Most Known Unknown
Discussion Starter #15,296
done deal for the trans, now moving onto the transfer case
i TRIED to get Dexron6 since its plastered all over the internet about it being in the owners manual, so i gave it a shot but between Vatozone and OHHHReily's they only had one quart between them, so i used the extra Transynd i had and made it happen.
first things first, make sure your new jug pump kit fits before you start moving a full container around under the truck!
older picture obviously since the trans and Tcase were done before the wash...since the truck is dirty but i like to keep my pictures together :bd03
the bottom plug is your drain, and the one above is for the guys running 2 quarts (which in reality you just fill till it starts puking and plug it up), and the 3 quart guys i read go through the speed sensor up top..,makes sense
i assume this is normal, according to posts online it doesn't look bad
Most Known Unknown
Discussion Starter #15,297 (Edited)
got my thread taped' plug ready
once ready, it was installed and the filling began.
drumstick anyone?
waited for it to level off, and i pumped a tad more in there and plugged up the fill port
complete, and dated
Happy birthday bud.
Most Known Unknown
Sounds messy!
